qwizzie
I have decided to bundle some of my masternodes on 1 VPS, which has several dedicated IP addresses.
I have set multiple useraccounts on my main IP address, each useraccount will have its own
dash.conf & blockchain (i have large hdd space there so the space it takes is not a problem).
Can someone please verify if the setup i have in mind will actually work on the remote VPS side.
I'm not sure about the bind command & rpcport (Dash Central seems to use the 9998 port and i plan on using their push and restart script).
Any improvements / fixes / suggestions will be highly appreciated.
dash.conf
dash.conf
dash.conf
Port 6000, 6001 and 6002 will get added to my Ubuntu firewall
(ufw allow 6000/tcp etc)
dash.conf
rpcuser=xxxx1Axxxx
rpcpassword=xxxx1Bxxxx
rpcallowip=127.0.0.1
externalip=IPADDRESS
bind=IPADDRESS
rpcport=6000
listen=1
server=1
daemon=1
logtimestamps=1
maxconnections=30
masternode=1
masternodeprivkey=MNPRIVKEY
dash.conf
rpcuser=xxxx2Axxxx
rpcpassword=xxxx2Bxxxx
bind=IPADDRESS
rpcport=6001
listen=1
server=1
daemon=1
logtimestamps=1
maxconnections=30
masternode=1
dash.conf
rpcuser=xxxx3Axxxx
rpcpassword=xxxx3Bxxxx
bind=IPADDRESS
rpcport=6002
listen=1
server=1
daemon=1
logtimestamps=1
maxconnections=30
masternode=1
