RC4 issues, bugs & feature requests
flare
May 18, 2014
2,286
2,404
Germany
Dear community,
RC4 is live. I therefore created a new thread to discuss issues, bugs & feature requests with RC4 in mainnet.
If you think you found a bug, feel free to use our bugtracker to report it --> http://jira.darkcoin.qa
If you are not sure if it's a bug or you want to discuss your feature requests, feel free to discuss them here.
These are the latest CI-builds
CI-builds for v0.9.12.32-g70ab70d
Windows 32bit:
http://bamboo.darkcoin.qa/artifact/DWD-DRK/QTL/build-109/gitian-win-darkcoin-bin/32/darkcoin-qt.exe
http://bamboo.darkcoin.qa/artifact/...oin-bin/32/darkcoin-0.9.12.32-win32-setup.exe
Mac OS X:
http://bamboo.darkcoin.qa/browse/DOD-DRK-92/artifact/QTL/gitian-osx-darkcoin/DarkCoin-Qt.dmg
Linux 32bit:
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-89/gitian-linux-darkcoin-bin/bin/32/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-89/gitian-linux-darkcoin-bin/bin/32/darkcoind
Linux 64bit:
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-89/gitian-linux-darkcoin-bin/bin/64/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/BL-DRK/QTL/build-89/gitian-linux-darkcoin-bin/bin/64/darkcoind
CI-builds for v0.10.12.32-g231bfa3
Windows 32bit:
http://bamboo.darkcoin.qa/artifact/...arkcoin-rc-darkcoin-qt-bin/32/darkcoin-qt.exe
http://bamboo.darkcoin.qa/artifact/...coin-rc-darkcoind-bin/32/daemon/darkcoind.exe
Mac OS X:
http://bamboo.darkcoin.qa/browse/DOD-DRKRC-30/artifact/QTL/gitian-osx-darkcoin-rc/DarkCoin-Qt.dmg
Linux 32bit:
http://bamboo.darkcoin.qa/artifact/...tian-linux-darkcoin-rc-bin/bin/32/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/...gitian-linux-darkcoin-rc-bin/bin/32/darkcoind
Linux 64bit:
http://bamboo.darkcoin.qa/artifact/...tian-linux-darkcoin-rc-bin/bin/64/darkcoin-qt
http://bamboo.darkcoin.qa/artifact/...gitian-linux-darkcoin-rc-bin/bin/64/darkcoind
The Darkcoin Development Team
flare
May 18, 2014
2,286
2,404
Germany
eduffield said:
****** PLEASE UPDATE TO v9.12.28 (Stable) OR 10.12.28 (RC) *******
The unconfirming issue was caused by DS going too fast once and awhile and the view not being able to keep up with what inputs were spent. This caused double spends in about 2% of cases. To fix this I've introduced a limit where darksend will only denominate once a block.
If you have a long standing unconfirmed transaction, simply right click the transaction, copy the txid. Then execute the command "erasetransaction txid" in the console. After that reopen the client with the command -salvagewallet, and the money should be back.
It will still be possible to mix with clients that haven't updated, so avoid activating darksend for a day or so while the network updates. This update is backwards compatible, so masternodes need not update.
Source: Compile if you are running a pool, exchange, etc.
https://github.com/darkcoinproject/darkcoin
9.12.28 (Stable) Binaries: Does not include Darksend
Windows.exe: https://raw.githubusercontent.com/d...in-binaries/master/darkcoin-0.9.12.28-win.zip
Windows installer: https://raw.githubusercontent.com/d...ies/master/darkcoin-0.9.12.28-win32-setup.exe
Mac OSX: https://raw.githubusercontent.com/d...in-binaries/master/darkcoin-0.9.12.28-osx.dmg
Linux: https://raw.githubusercontent.com/d...naries/master/darkcoin-0.9.12.28-linux.tar.gz
10.12.28 (RC) Binaries: Includes Darksend - Masternode Operators
Windows .exe: https://raw.githubusercontent.com/d...inaries/master/rc/darkcoin-0.10.12.28-win.zip
Mac OSX: https://raw.githubusercontent.com/d...inaries/master/rc/darkcoin-0.10.12.28-osx.dmg
Linux: https://raw.githubusercontent.com/d...es/master/rc/darkcoin-0.10.12.28-linux.tar.gz
Light
346
256
233
I think Evan meant "this caused double spending attempts" and not actual double spending. Right?
stonehedge
696
333
233
I am seeing some reports that the disable darksend checkbox is being ignored in this version. Can somebody confirm if this is the case and whether there is a workaround? Maybe something in the conf file?
flare
May 18, 2014
2,286
2,404
Germany
This bug is confirmed and fixed in v29 - update coming soon.
Reactions: stonehedge
3,638
3,536
Running .28 in testnet for about an hour now and it seems the same old story (rounds=2) -> 9 denominations (4 "gray") and no anonymized coins
Is there anyone else having the same issue?
flare
May 18, 2014
2,286
2,404
Germany
eduffield said:
****** PLEASE UPDATE TO v9.12.29 (Stable) OR 10.12.29 (RC) *******
Fixed the reading/writing of the DisableDarksend option in the config and disabled darksend by default. If users want to enable it they can go into the configuration to turn it on.
9.12.29 (Stable) Binaries: Does not include Darksend
Windows.exe: https://raw.githubusercontent.com/d...in-binaries/master/darkcoin-0.9.12.29-win.zip
Windows installer: https://raw.githubusercontent.com/d...ies/master/darkcoin-0.9.12.29-win32-setup.exe
Mac OSX: https://raw.githubusercontent.com/d...in-binaries/master/darkcoin-0.9.12.29-osx.dmg
Linux: https://raw.githubusercontent.com/d...naries/master/darkcoin-0.9.12.29-linux.tar.gz
10.12.29 (RC) Binaries: Includes Darksend - Masternode Operators
Windows .exe: https://raw.githubusercontent.com/d...inaries/master/rc/darkcoin-0.10.12.29-win.zip
Mac OSX: https://raw.githubusercontent.com/d...inaries/master/rc/darkcoin-0.10.12.29-osx.dmg
Linux: https://raw.githubusercontent.com/d...es/master/rc/darkcoin-0.10.12.29-linux.tar.gz
CI-builds for v29 available, updated OP
qwizzie
1,659
798
v10.12.29
Patiently awaiting incoming Darksent Denominate transactions .......
2014-08-14 20:42:05 keypool added key 1054, size=1001
2014-08-14 20:42:05 keypool reserve 54
2014-08-14 20:42:05 keypool keep 54
2014-08-14 20:42:05 CDarkSendPool::SendMoney() - Added transaction to pool.
2014-08-14 20:42:05 dsi -- tx in CTxIn(COutPoint(b478452f0a34ecc7c1dadbdb0cbd1856c6f0247adf7ddf773cf77fe88cebd00e, 4), scriptSig=)
2014-08-14 20:42:05 dsi -- tx in CTxIn(COutPoint(b478452f0a34ecc7c1dadbdb0cbd1856c6f0247adf7ddf773cf77fe88cebd00e, 0), scriptSig=)
2014-08-14 20:42:05 dsi -- tx in CTxIn(COutPoint(b478452f0a34ecc7c1dadbdb0cbd1856c6f0247adf7ddf773cf77fe88cebd00e, 1), scriptSig=)
2014-08-14 20:42:05 dsi -- tx in CTxIn(COutPoint(b478452f0a34ecc7c1dadbdb0cbd1856c6f0247adf7ddf773cf77fe88cebd00e, 9), scriptSig=)
2014-08-14 20:42:05 dsi -- tx in CTxIn(COutPoint(b478452f0a34ecc7c1dadbdb0cbd1856c6f0247adf7ddf773cf77fe88cebd00e, 10), scriptSig=)
2014-08-14 20:42:05 dsi -- tx in CTxIn(COutPoint(b478452f0a34ecc7c1dadbdb0cbd1856c6f0247adf7ddf773cf77fe88cebd00e, 11), scriptSig=)
2014-08-14 20:42:05 dsi -- tx in CTxIn(COutPoint(b478452f0a34ecc7c1dadbdb0cbd1856c6f0247adf7ddf773cf77fe88cebd00e, 12), scriptSig=)
2014-08-14 20:42:05 RelayDarkSendIn - found master, relaying message - 54.64.7.206:19999
2014-08-14 20:42:05 DoAutomaticDenominating : Running darksend denominate. Return ''
2014-08-14 20:42:05 new darksend queue object - 54.64.7.206:19999
2014-08-14 20:42:05 CDarkSendPool::UpdateState() == 2 | 2
2014-08-14 20:42:05 DarkSendStatusUpdate - state: 2 entriesCount: 1 accepted: 1 error:
2014-08-14 20:42:05 CDarkSendPool::StatusUpdate - set sessionID to 509051
2014-08-14 20:42:05 CDarkSendPool::StatusUpdate - entry accepted!
2014-08-14 20:42:05 DarkSendStatusUpdate - state: 2 entriesCount: 1 accepted: -1 error:
2014-08-14 20:42:05 darkSend Status => Your transaction was accepted into the pool!
2014-08-14 20:42:07 Flushing wallet.dat
2014-08-14 20:42:07 Flushed wallet.dat 188ms
2014-08-14 20:42:09 darkSend Status => ( Entries 1/2 )
2014-08-14 20:42:22 darkSend Status => Waiting for more entries (1/2 ) .
catlasshrugged
20
23
13
About how long does it take folks to start and complete the DarkSend process on the testnet? I'm using v10.12.29 with settings:
DarkSend rounds to use: 3
Amount of Darkcoin to keep anonymized: 100
(unchecked) Disable Darksend
qwizzie
1,659
798
difficult to say .. i have a feeling not many are testing it here on testnet right now and also most will not have updated to latest update
as that was just released.
If you feel like testing on testnet then create seperate folder for it,
link to it (for example : put -datadir=D:\DarkcoinTestData in the shortcut towards darkcoin-qt.exe if yr using a windows wallet)
and put testnet=1 in your darkcoin.conf and place it in D:\DarkcoinTestData
Use this site to get free drk : https://drkipn.com/test/faucet/
flare
May 18, 2014
2,286
2,404
Germany
Thanks flare. I'll update to v29 when available.
v10.12.29
Network needs to update to v28+ first... waiting too :)
Reactions: qwizzie
catlasshrugged
20
23
13
link to it (for example : put - datadir=D:\DarkcoinTestData in the shortcut towards darkcoin-qt.exe if yr using a windows wallet)
I'm using the Linux client. As far as I can tell, starting the client with the -testnet client seems sufficient to get it to connect to the testnet without modifying any configuration files, but does anyone know otherwise?
stonehedge
696
333
233
Eh? You know what? I give in. I'm totally out of my depth. I haven't got enough DRK to keep paying Yidakee to update my nodes. Every time I try to follow instructions I end up breaking something. And there I was thinking that I had to update my masternodes to 29 and I think I've broken one of them whilst trying to do so. I'm just going to go to bed early (GMT+1 here) and see where things are in the morning and if there is any more clarity on what needs to be done, to what and by who I'll be a happy man. /rantover (more upset that I've been tinkering and been caught out again :( )
qwizzie
1,659
798
not all updates are mandatory for MN owners ... someone pls inform us which update was mandatory for MN owners ? was it 10.12.26 ?
flare
May 18, 2014
2,286
2,404
Germany
Yes, the last mandatory update was 10.12.26
eduffield said:
****** PLEASE UPDATE TO v9.12.26 (Stable) OR 10.12.26 (RC) *******
This update addresses a few small issues that presented themselves after we launched on mainnet. Please update ASAP. The protocol version was changed, so this is a mandatory update. Sorry for any inconvenience.
Reactions: vertoe and qwizzie
flare
May 18, 2014
2,286
2,404
Germany
-testnet as parameter is sufficient to connect your client to testnet. Nothing more needed.
mbilker
55
Upgraded my MN (66.172.33.248:19999) to v0.10.12.29 (flare build 29 linux 64-bit) for further testing. May start up a node to run on mainnet using the released RC4 version.
thelonecrouton
1,135
813
Breaking stuff is how you learn! :D
Use testnet, with tDRK it doesn't matter and the principles are all exactly the same, so you'll know what you're doing (and what not to do!) on main-net.
thelonecrouton
1,135
813
There's something weird going on with the options screen, specifically when you click the Apply button after making some change, that spikes CPU usage to the max for far longer than seems reasonable. Once the OK button eventually becomes clickable, CPU usage drops way back down and the slowdowns-to-the-point-of-complete-unusability I've been having mostly go away. They only mostly stay away though with Darksend disabled.
edit: ignore the above, still getting random periods of CPU being hammered and GUI halt. Can't see anything in the debug log as it scrolls by that obviously precipitates this behaviour, or ends it. Grump.
JGCMiner
Jun 8, 2014
364
217
Flare, any update on the Darksend rounds>1 issue? Or is the dev team still looking into that?
v0latile
I think the client needs an auto-update downloader or at least an update check dialog as I can't keep up with checking forums every 5 minutes for new releases. No sooner do I download a new binary and update another update comes out and im behind again.
Reactions: catlasshrugged
catlasshrugged
20
23
13
Bug (that you're probably already aware of): Invalid number (-2) in "Darksend Rounds" column in the Coin Control window. (v10.12.29 linux)
We have reproduced the issue, still looking at it. Stick to rounds=1 in the meantime.
Thanks for addressing this, I was experiencing issues with this as well.
Reactions: Walter and flare
