Question about masternode IP changes
darkness
Hi all,
My masternode has been up and running fine for a while, but recently my ip address changed and now the node no longer shows up on dashninja.pl. The old ip is still there, however, with "port closed". How long does this take to update? and is there a command to update it by force? since no doubt my ip will change again at some point in the future.
By logging into the node I can see that it is up, and has at least 2 incoming connections to it at the moment.
Thanks for any help.
Are you hosting this on your own PC? Generally not such a great idea since your IP changes all the time but MangledBlue is probably right on changing the IP info in the dash.conf and masternode.conf files.
