PPTP connectivity problem
rootwilliamson
Hi, I have a VPN but when I configured a PPTP connection, it can’t connect because the router blocks the output. What the actual issue I don’t know? Please help.
Have you looked carefully at the settings? If the problem is in the router, then I advise you to visit the manufacturer’s website and update the firmware. I often used a VPN before to download movies and watch streaming video. A firmware update always helped me. Currently, I refused this because there are too few trusted IP addresses in the world. I began to use ShowBox. Here is a search for torrents so there is no need for additional encryption.
Thank You to reply. I read carefully the router setting and follow their steps as well. In the mean time I search on google and get some guide like
https://www.cactusvpn.com/beginners-guide-to-vpn/what-is-pptp/
https://www.lifewire.com/pptp-point-to-point-tunneling-protocol-818182
https://www.purevpn.com/what-is-vpn/protocols/pptp
But still nothing. Do you have any solution.
These guides teach you how to set up a vpn on your router. You need to search for how to update your router's firmware. Will solve your problem!
