I'll check and come back to youThe latest build (.49) gives me an error when attempting to verify the PGP signature.
I am uslng toolsley, is anybody else seeing this? Afraid to use it now.
Pablo.
Linux64 verifies well for meThe latest build (.49) gives me an error when attempting to verify the PGP signature.
Pablo.
Does not work for me either -maybe it's a bug in toolsley?Hey,
dash-0.12.0.49-linux64.tar.gz
Could you give it a go on toolsley? https://www.toolsley.com/verify.html
I got all the files from the downloads section of dashpay.io
Pablo.
Ok, thanks for taking the time flare
Must be a file-size limit - i resigned the binary with my own key, and got the same result: INVALIDOk, thanks for taking the time flare. I'll have to learn how to do it on the console if thats the case
Pablo.
Please post if you get a favorable reply.
Pablo.
And now it works:Hi,
Apparently there was a bug in the file reader code that only triggered for files between 10 and 20 megs. (The loader works on 10 meg slices at a time to reduce memory usage and improper initialization made it fail to read the file completely when it was more than one but less than 2 full slices in size.)
It also affected the Hash&Validate tool.
Both should be fixed now.
Could you try it again?
Thanks,
Viktor
Sure, it runs without installation inside the browser.flare -- can we use this tool with windows?
Where do we get the .asc file? I only see the signature from here: https://www.dashpay.io/binaries/dash-0.12.0.50-win32.zip.ascSure, it runs without installation inside the browser.
--> https://www.toolsley.com/verify.html
Just drag & drop the file you want to verify and the corresponding signature (.asc) - the key will be retrieved automagically
Follow the white rabbit, and read your last sentence againWhere do we get the .asc file? I only see the signature from here: https://www.dashpay.io/binaries/dash-0.12.0.50-win32.zip.asc
Also, for general purposes, you can always copy and paste a key or signature into a text file and change the extension to .ascWhere do we get the .asc file? I only see the signature from here: https://www.dashpay.io/binaries/dash-0.12.0.50-win32.zip.asc
Sorry, I kinda figured i would have to copy and save a .asc file but i just wanted to make sure. Thank you
That's what I did, works great... Lol, I couldn't get past Please wait... screen,Also, for general purposes, you can always copy and paste a key or signature into a text file and change the extension to .asc.
Pablo.
You need to upload the .asc file still - key and binary are ok.Sorry, I kinda figured i would have to copy and save a .asc file but i just wanted to make sure. Thank you
I uploaded this file after clicking on the "signature" icon from the far left... but it does not show on the screen.
Also is the key ID "0x4b..." a given key or how do we find it? I went ahead and typed this key in and this is what i have:
I have the .asc file. Just to make sure, I deleted and made another .asc file... it is an .asc file but for some reason i still can not upload the dang thing.Also, for general purposes, you can always copy and paste a key or signature into a text file and change the extension to .asc.
Pablo.
Did you try "Save link as..." in your browser?I have the .asc file. Just to make sure, I deleted and made another .asc file... it is an .asc file but for some reason i still can not upload the dang thing.
No i didn't. I opened the page, copied and pasted and saved it as an .asc file under extension "All files".. so it is an .asc file.
Try "Save link as...." and try to upload againNo i didn't. I opened the page, copied and pasted and saved it as an .asc file under extension "All files".. so it is an .asc file.
