Full Disclosure: I work for one of the major block explorers listed below.
I run 3 nodes (non master) on three separate servers in 3 different areas.
Here's the genesis of the event:
- At 4:04AM EST i was alerted that DASH had not been updated for an hour. This is unusual for DASH.
- I check and sure enough, it's been an hour. I then check 2 other sites. They're also stuck at the same block 1028180.
- I tried restarting one of the nodes, but it didn't help.
- Got back to it in the morning and tried to search more.
- I then check out explorers: NOTE I CANNOT POST LINKS YET
- Block Cypher is stuck at 1028181
- Explorer Dash Org site is stuck at 1028159
- Longhorn BullPay is stuck at 1028181
- Chain So is stuck at 1028181
- My 3 non-master nodes are stuck at 1028181
