Low Work Unit
Discussion in 'Mining' started by panic, May 15, 2014.
  1. panic
    panic New Member
    May 15, 2014
    I'm new to this coin and come from the scrypt crowd so seeing a Work Unit of 0.109/m with a hashrate of 7800Kh/s over 6 GPU's is a little alarming.
    Is it normal to have such a low WU?
    https://i.imgur.com/Oi84YCR.png
    The GPU's are all Gigabyte R9 270x Windforce models.
  2. ErrorId
    ErrorId Member
    Mar 9, 2014
    158
    41
    My GPU does about 1.8MH and I have a 0.024 WU so yes I would say that its normal.
  3. fra55
    fra55 Member
    Mar 26, 2014
    143
    14
    68
    WU is Work Utility. It's not the same as scyrpt, you have to divide your hashing speed by 72 (actually is 72,xx) to geet your W.U.
    0.109 is correct for your speed
