Linux build
Discussion in 'Daemon and QT Wallet Guides' started by Jeztah, May 5, 2019.
  1. Jeztah
    Jeztah Active Member
    Oct 9, 2014
    181
    145
    Looking for a bit of help.
    A few years ago I ran multiple MNs, and never had a problem getting them running in linux. Fast forward to now and I'm struggling.
    Just ran make install and wanted to start dashd.
    [19:52][[email protected] dash]# /root/dash/src/dashd
    /root/dash/src/dashd: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /root/dash/src/dashd)
    /root/dash/src/dashd: /lib64/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /root/dash/src/dashd)
    /root/dash/src/dashd: /lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /root/dash/src/dashd)
    /root/dash/src/dashd: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.22' not found (required by /root/dash/src/dashd)
    /root/dash/src/dashd: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /root/dash/src/dashd)
    So it looks like the NEW version of glib I had to install to compile something else is the dominant one instead of the one under my dash directory.
    How can I correct this?
    Thanks!!
    #1 Jeztah, May 5, 2019
  2. Antti Kaikkonen
    Antti Kaikkonen Active Member
    Jun 20, 2017
    257
    167
    Dash Address:
  3. Jeztah
    Oct 9, 2014
    181
    145
  4. rosita
    rosita Member
    Aug 6, 2018
    82
    68
    Do you think it is a good idea to use Linux?
    • Useful Useful x 1
  5. Jeztah
    Oct 9, 2014
    181
    145
    Solved with "cp /usr/local/lib64/libstdc++.so.6.0.22 /usr/lib64/libstdc++.so.6"
    • Like Like x 1
