Issues setting up 5850
fader187
Hi
I am trying to setup my 5850 rig to mine but nothing is happening when I do so. When using the normal SGMiner I just get a cmd prompt which says "[14:27:30] Started sgminer 4.0.0" which then crashes after a minute or so.
I have also tried using sph-sgminer_x11mod_b2 which I can get working to an extent but at lower than expected hash rates (about 950mhs) The settings I use for this are:
setx GPU_MAX_ALLOC_PERCENT 100
setx GPU_USE_SYNC_OBJECTS 1
cd\sgminerx11
sgminer.exe --kernel darkcoin -o stratum+tcp://stratum-eu.suchpool.pw:3335 -u MYUNAME -p x --intensity 13 --worksize 256 -g 2 --thread-concurrency 5120 --temp-target 73 --gpu-fan 50-100 --no-submit-stale --gpu-engine 860 --gpu-memclock 1100
Any ideas would be greatly appreciated!
