Help setting up SGMINER
xxnwoxx
Hi, I've recently started mining and I'm having difficulty setting up my SGMINER. Here is what it's saying. Did I do something wrong?
My BAT file is :
setx GPU_MAX_ALLOC_PERCENT 100
setx GPU_USE_SYNC_OBJECTS 1
sgminer.exe -k darkcoin -o stratum+tcp://x -u x -p x --failover-only -o stratum+tcp://x -u x -p x --xintensity 100 --gpu-threads 1 --no-submit-stale
You're clearly missing one of the .cl files (blake.cl) in the \kernel directory in the sgminer which you are using.
Download one of the recent sgminer versions which includes all the required files and try again (see bitcointalk.org).
