The GTX670 only supports CUDA 3.0, from the command line in your screenshot it looks like you are trying to run ccminer35.exe which is the version for cards supporting CUDA 3.5
Try running ccminer30.exe instead with the same parameters, it comes as part of the ccminer package so you already have it.
(Also be careful not to post your mining username and password in screenshots!)
