Fungability, Privacy and Privatesend
Dworf
Active member
After following this issue some time I do not see a good solution for now. And that is a pretty poor situation. DASH has the most advanced governance structure, the fastest payment engine but only a poor mixing based privacy solution.
From my point of view there will be a simple and efficient solution for this: Zerocash
"Zerocash is a novel cryptographic payment scheme that creates a separate anonymous currency, existing alongside a (non-anonymous) base currency, which we refer to as Basecoin [may be DASH]. Each user can convert (non-anonymous) basecoins into (anonymous) Zerocash coins, which we call zerocoins. Users can then send zerocoins to other users, and split or merge zerocoins they own in any way that preserves the total value. Users can also convert zerocoins back into basecoins, though in principle this is not necessary: all transactions can be made in terms of zerocoins, if the parties involved support these."
Why not adapt this cutting edge technology and solve the problem once and for all.
