dash daemon is killed by OOM killer
Discussion in 'Daemon and QT Wallet Support' started by pianisteg, Sep 25, 2015.
  1. pianisteg
    pianisteg New Member
    Aug 21, 2015
    12
    Out of memory: Kill process 22672 (dashd) score 710 or sacrifice child
    Killed process 22672 (dashd) total-vm:8553416kB, anon-rss:6572092kB, file-rss:0kB
    I can give more details to developers of dash daemon.
    Dash Core Daemon version v0.12.0.45-b2b2cef
  2. eduffield
    eduffield Core Developer
    Mar 9, 2014
    1,084
    5,319
    How much memory does you machine have? We have seen this issue when the VPS has less than 512M available. There are a couple processes (with masternodes only), that spike the memory briefly, then it returns to normal. Are you running a masternode?
  3. pianisteg
    Aug 21, 2015
    12
    No, just usual node.
    8Gb of RAM, 6.5Gb is free.
  4. pianisteg
    Aug 21, 2015
    12
    2015-09-25 17:05:55 mnw - invalid message - Masternode not in the top 10 (11)
    2015-09-25 17:05:55 CMasternodePaymentWinner::IsValid - Masternode not in the top 10 (11)
    2015-09-25 17:05:56 CMasternodePaymentWinner::IsValid - Masternode not in the top 10 (13)
    2015-09-25 17:05:56 mnw - invalid message - Masternode not in the top 10 (13)
    2015-09-25 17:05:57 CMasternodePaymentWinner::IsValid - Masternode not in the top 10 (11)
    2015-09-25 17:05:57 mnw - invalid message - Masternode not in the top 10 (11)
    2015-09-25 17:05:57 CMasternodePaymentWinner::IsValid - Masternode not in the top 10 (12)
    2015-09-25 17:05:57 mnw - invalid message - Masternode not in the top 10 (12)
    2015-09-25 17:05:58 CMasternodePaymentWinner::IsValid - Masternode not in the top 10 (11)
    2015-09-25 17:05:58 mnw - invalid message - Masternode not in the top 10 (11)
    2015-09-25 17:05:59 CMasternodePaymentWinner::IsValid - Masternode not in the top 10 (12)
    2015-09-25 17:05:59 mnw - invalid message - Masternode not in the top 10 (12)
    And 100% CPU.
  5. pianisteg
    Aug 21, 2015
    12
    sending usual kill (15):
    22912 wallet    20   0 7876m 5.7g  716 R 68.4 74.1   3:12.34 dash-shutoff
  6. flare
    flare Administrator
    Dash Core Team Moderator
    May 18, 2014
    2,287
    2,406
    0.12.0.45 had a memory leak, please update to latest version (0.12.0.53)
    ---> https://github.com/dashpay/dash/issues/568
    #6 flare, Sep 25, 2015
    • Like Like x 2
  7. pianisteg
    Aug 21, 2015
    12
    Thanks. Downloaded and started.
    After start it takes 4-5Gb RAM, why?
    All other wallets use less than 1Gb.
  8. splawik21
    splawik21 Grizzled Member
    Dash Core Team Foundation Member Dash Support Group Moderator
    Apr 8, 2014
    1,916
    1,273
    It always consumes the max amount available.
    I have 512mb + 512 swap and it always consumes almost everything :)
    Hopw about the stability on v53?
  9. flare
    flare Administrator
    May 18, 2014
    2,287
    2,406
    It should level out at ~350M after some time - at least that's what I see on many of my processes :)
    Blockchain verification takes a lot of RAM, building the masternode list as well.
