Dash core does not respond
Solaso
I have MNs more than 10. Often after starting Dash and then start-missing or start-disabled, Dash core does not respond. So I kill process in task manager.
Dash core local and server are latest, now 0.12.0.56
Please help.
Please let us know your version , any text on debug log.
By the way, please try latest version and make sure that you already unlock the wallet before perform 'masternode start-missing or start-disabled'.
Dear, I have latest version. Purse unlock
I can send log in private message, ok?
Please help.
Did you wait until the wallet was fully synced, including the "Synchronizing additional data" part?
That's required for all start-* commands.
However, the wallet shouldn't hang when this exception is thrown.
UdjinM6 ?
Yes i noticed the same that ....
masternode start* password freezes the client but when unlocking the wallet first and then issuing the start command works fine.
I already sent. Thank you.
Yes, masternode start* password freezes. But also sometimes when unlocking the wallet first, also freezes. I deleted dat files, exclude wallet and masternode, but not helped.
May be client freeze when MN more than 50 or 100?
The amount does not has impact here as I saw this problem on 1 and more nodes too.
I have also experienced the issue where the client freezes and crashes when issuing masternode start-* passphrase. It took me a long time to figure out I had to unlock the wallet first..
remember
masternode start-*
only use that to start MN once and first, as this will put you back in the beginning of payment/winner line
(do not use it to bump your MN, it does not work)
