DarkcoinD+Libboost+chroot=Runtime-Error
Figlmüller
85
45
Vienna, Austria
Hi,
I just wanted to report a problem which came up while trying to launch the darkcoin daemon in a chroot environment (together with an optimized kernel).
I'm currently running and compiling all instances under Debian 7 Wheezy using the libraries available on the stable tree.
Once I try to run darkcoind it immeadiately crashes with the following message:
runtime error: locale::facet::_S_create_c_locale name not valid
It seems that this is being caused by the boost libraries.
The only way to get around this is to set LC_ALL to C.
CSS:
LC_ALL="C"
export LC_ALL
Is there a way to address this issue in the darkcoin code?
