Can someone briefly explain "denominated funds" to me?
vertoe
Three of Nine
Mar 28, 2014
2,573
1,652
Unimatrix Zero One
You own address X1A and everyone knows that this is your address. You hold 100 DRK there.
Denomination is a early process of darksend. A denomination transactions splits your funds in 100, 10, 1 and 0.1 pieces of DRK and sends it to fresh unsused addresses X9D, X7Z and X6R. These founds are now denominated because the addresses are not obviously your addresses.
This is the simplyfied versoin to explain that for you. To really denominate your coins, they will be mixed with other inputs from Guy B and his address X2B and gal C and her address X3B.
One darksend round simplyfied:
X1A, X2B, X3C ---> Split coins in amounts (power of ten) ---> Mix inputs and outputs in a single transaction ---> Denominated funds on X9D, X7Z and X6R.
If you do this multiple times through up to 16 rounds for all your available funds, your holdings of Darkcoin are almost impossible to trace back to your original holding address X1A.
splawik21
Apr 8, 2014
1,943
1,303
Would you suggest 16 rounds to be on the safe side vertoe ?
well there is always the possibility of tracking the mixed funds like 0.00000000001% :D if not less.... :) but if you start mixing mixed coins the possibility of tracking is like 0,00000000000000000001% is it enough? If not do another 16x mixing.... :D:D
Reactions: Vyazhan
Vyazhan
62
20
Thanks :D And just because I don't want to move through dozens of pages of text: How often do I have to pay the 0.1DRK collateral fee? and is it ok if I stop mixing during the process or logout or do I need to wait until the progress bar is complete?
Reactions: splawik21
splawik21
Apr 8, 2014
1,943
1,303
It`s better to start mixing till the end, because you don`t risk to hit 0.1 so often.
The probability of corrateral is higher when you have shit internet connection or interuptions of your network during the mixing.
The 0.1 anominisation amount is possible 1 out of 40 rounds.
Reactions: moli and Vyazhan
moli
3,255
1,830
I would. I asked Evan for 25 rounds but now we've got 16/17 rounds. You should try to anonymize some coins at these rounds and then try to trace your coins back to your origin address to see if you can! :D
Reactions: Vyazhan
Vyazhan
62
20
I'm a fan of unlimited mixing, but 16 should be enough.
Thanks guys for the heads-up! It's working really well for me right now, albeit a bit slow bit rather safe than sorry, right :D
Just ONE more question and I will go back to my cave: "Is it ok to have a max of let's say 1000DRK/16Rounds configured in the client while only actually having a few dozen DRKS right now and then keep adding/removing funds from the main wallet and/or the DarkSend portion of the wallet OR is it better to have one supply of let's say 100DRK, DS it in one go and then use a different wallet for other incoming/outgoing stuff until I have depleted the entire DS?
Just checking how to operate this the best way :)
moli
3,255
1,830
If you set an "Amount to keep anonymized" higher than what you have in your wallet, it's ok, because it will only anonymize what you have. It's also okay to add to your wallet while mixing, but be careful in removing/spending your funds so much while DS is mixing because you can get collateral fees, like what happened to me here:
https://darkcointalk.org/threads/v0-11-1-instantx-release.3923/page-5#post-41763
And UdjinM6 explained it here:
https://darkcointalk.org/threads/v0-11-1-instantx-release.3923/page-5#post-41773
Your coins will not be anonymized to every little duff because you have change left, and my suggestion is not to send your change with your anonymized coins but just keep the change until you add more DRK to the wallet and start the DS cycle again.
Vyazhan
62
20
Thanks moli, this is what I was looking for :)
Thanks as well for the heads-up, this will make my life a lot easier and cheaper!
Much <3 to the DRK!
Reactions: moli
