****** PLEASE UPDATE TO v10.17.0 *******
- This supports a complete InstantX implementation. This implementation has teeth, the masternodes have the final say if a specific transaction will make it into the block. To do this, they can actually orphan conflicting blocks, up to five blocks deep if an attack happened. To pull off such an attack, the attacker would propagate a lock request, masternodes would form a lock, then the attacker would mine a conflicting transaction. With this implementation, that block will be orphaned.
- Current setting, requires 7 of 10 masternodes to form a lock
- Masternodes MUST have their port open, or they will be forced into an inactive state (not implemented yet)
- Each InstantX transaction will use a different set of masternodes. These are chosen based on the POW hash of the block that transaction was included in. This means you can't tamper with the masternodes you'll use, but the system can use all masternodes at once.
- Masternode network backwards compatibility, dsee/dseep messages now will be backwards/forwards compatible. Masternodes in the list will have protocol versions, so the code will know which are compatible with their versions.
- Gradual forced masternode updates, the network will now support paying out-of-date masternode versions for a period of time while allowing the network to update. Each update will have a deadline (probably 1 week after an update is released) before payments stop. This means the network could support multiple versions of Darksend at once, which is ideal.
- Support "min protocol version" for Darksend, allowing mixing between different versions of compatible protocols.
- New parameter -masternodeminprotocol = Only track masternodes beyond this version
- New parameter -wallet = Use a wallet other than wallet.dat (UdjinM6)
- New command "masternode list protocol"
- Wallet will stay locked during Darksend and only be able to mix (UdjinM6)
- Improved CalculateScore, using a much harder to trick calculation
How can you help?
- Run a masternode
- Point hashing power at my pool (I'm going to be attacking InstantX and will need most of the hashing power)
- Test InstantX
**** Downloads : v0.10.17.0 ***********************************
Source: https://github.com/darkcoin/darkcoin/tree/instantx
Windows 32bit:
https://github.com/darkcoinproject/darkcoin-binaries/raw/master/instantx/windows/darkcoind.exe
https://github.com/darkcoinproject/darkcoin-binaries/raw/master/instantx/windows/darkcoin-qt.exe
Mac OS X:
https://github.com/darkcoinproject/...aster/instantx/mac/darkcoin-0.10.17.4-osx.dmg
Linux 32bit:
https://github.com/darkcoinproject/darkcoin-binaries/raw/master/instantx/linux/32/darkcoin-qt
https://github.com/darkcoinproject/darkcoin-binaries/raw/master/instantx/linux/32/darkcoind
Linux 64bit:
https://github.com/darkcoinproject/darkcoin-binaries/raw/master/instantx/linux/64/darkcoin-qt
https://github.com/darkcoinproject/darkcoin-binaries/raw/master/instantx/linux/64/darkcoind
// Deterministically calculate a given "score" for a masternode depending on how close it's hash is to
// the proof of work for that block. The further away they are the better, the furthest will win the election
// and get paid this block
uint256 CMasterNode::CalculateScore(int mod, int64 nBlockHeight)
if(pindexBest == NULL) return 0;
uint256 hash = 0;
if(!darkSendPool.GetLastValidBlockHash(hash, mod, nBlockHeight)) return 0;
uint256 hash2 = HashX11(BEGIN(hash), END(hash));
// we'll make a 4 dimensional point in space
// the closest masternode to that point wins
uint64 a1 = hash2.Get64(0);
uint64 a2 = hash2.Get64(1);
uint64 a3 = hash2.Get64(2);
uint64 a4 = hash2.Get64(3);
//copy part of our source hash
int i1, i2, i3, i4;
i1=0;i2=0;i3=0;i4=0;
memcpy(&i1, &a1, 1);
memcpy(&i2, &a2, 1);
memcpy(&i3, &a3, 1);
memcpy(&i4, &a4, 1);
//split up our mn hash
uint64 b1 = vin.prevout.hash.Get64(0);
uint64 b2 = vin.prevout.hash.Get64(1);
uint64 b3 = vin.prevout.hash.Get64(2);
uint64 b4 = vin.prevout.hash.Get64(3);
//move mn hash around
b1 <<= (i1 % 64);
b2 <<= (i2 % 64);
b3 <<= (i3 % 64);
b4 <<= (i4 % 64);
// calculate distance between target point and mn point
uint256 r = 0;
r += (a1 > b1 ? a1 - b1 : b1 - a1);
r += (a2 > b2 ? a2 - b2 : b2 - a2);
r += (a3 > b3 ? a3 - b3 : b3 - a3);
r += (a4 > b4 ? a4 - b4 : b4 - a4);
LogPrintf(" -- MasterNode CalculateScore() n2 = %s \n", n2.ToString().c_str());
LogPrintf(" -- MasterNode CalculateScore() vin = %s \n", vin.prevout.hash.GetHex().c_str());
LogPrintf(" -- MasterNode CalculateScore() n3 = %s \n", n3.ToString().c_str());*/
return r
- Run a masternode
- Test InstantX
Windows 32bit:
Mac OS X:
Linux 32bit:
Linux 64bit:
