Thanks a lot! It woked. when i start my mainnet wallet should I remove the darkcoin.conf file? Will I have to sync with the weeks of blockchain again?Start your wallet with "testnet=1" in darkcoin.conf
check the tx you sent, I think 1000 tdrk is vout #1 and payout is vout #0Evan, something is odd, my normal client (0.9.12.0) which is solomining is receiving masternode payouts
Code: [ { "account" : "", "address" : "mmfZtnkHyxQAfTFj8ThS8MpvXyJ4pMFDVz", "category" : "immature", "amount" : 41.60000000, "confirmations" : 17, "generated" : true, "blockhash" : "0000000066a3f44cd4ed54d900fc2f2fa145fec7f9da4ad5344ad7df70961c3d", "blockindex" : 0, "blocktime" : 1405841190, "txid" : "c13e2d0604d3cb54ca000590b264c2605ee85511200a0a1cda08f8c17535df93", "time" : 1405841190, "timereceived" : 1405841210 }, { "account" : "", "address" : "mmfZtnkHyxQAfTFj8ThS8MpvXyJ4pMFDVz", "category" : "immature", "amount" : 39.60000000, "confirmations" : 14, "generated" : true, "blockhash" : "000000009fbc7d39248cac6e08fd5d0b88f67fa9a59248f60cbe8ea0843184c0", "blockindex" : 0, "blocktime" : 1405841419, "txid" : "e9524d73dfdd3db30aec6405bb2c0ec02c52b8fa88b88d7add53414da04c963d", "time" : 1405841419, "timereceived" : 1405841438 }, { "account" : "", "address" : "mmfZtnkHyxQAfTFj8ThS8MpvXyJ4pMFDVz", "category" : "immature", "amount" : 38.80000000, "confirmations" : 12, "generated" : true, "blockhash" : "00000000982d173024b4c1092e2521d50be3ec41ff973e90afd4d2fd2e8dfcbb", "blockindex" : 0, "blocktime" : 1405841665, "txid" : "5b684c72e6d816db0d8ff4e04b62252c4d2fe3e7e27425131fb10f5af266a487", "time" : 1405841665, "timereceived" : 1405841701 }, { "account" : "", "address" : "mmfZtnkHyxQAfTFj8ThS8MpvXyJ4pMFDVz", "category" : "immature", "amount" : 39.80000000, "confirmations" : 10, "generated" : true, "blockhash" : "0000000077e2f2f13bbe01ba13dea25b439a34c2335e747aa03e2024da4634f5", "blockindex" : 0, "blocktime" : 1405841713, "txid" : "dad23872b7d2e856aebc16b89bd0ec9281e423e96b0bf019fc1569a6bf169843", "time" : 1405841713, "timereceived" : 1405841731 }, { "account" : "", "address" : "mmfZtnkHyxQAfTFj8ThS8MpvXyJ4pMFDVz", "category" : "immature", "amount" : 37.80000000, "confirmations" : 9, "generated" : true, "blockhash" : "0000000098523f224cdcf48310e9cab0c7e45319d76764c514c0aa2ddd6098cc", "blockindex" : 0, "blocktime" : 1405841893, "txid" : "0c94ff635296a17b0b9dba1b0a125a5cada543f0b635f86bc050ce1657c8826d", "time" : 1405841893, "timereceived" : 1405841895 }, { "account" : "", "address" : "mmfZtnkHyxQAfTFj8ThS8MpvXyJ4pMFDVz", "category" : "immature", "amount" : 19.40000000, "confirmations" : 3, "generated" : true, "blockhash" : "000000002f0caff1c9472545c845890bb9648f62b26c63656a6d398d390599e2", "blockindex" : 0, "blocktime" : 1405842940, "txid" : "298a3a421621331c6a0c287f59bea1545da164408ff6982ff98ea02a8b1dc519", "time" : 1405842940, "timereceived" : 1405842968 } ]
Code:{ "version" : 91200, "protocolversion" : 70019, "walletversion" : 60000, "balance" : 334.40000000, "blocks" : 721, "timeoffset" : 12, "connections" : 8, "proxy" : "", "difficulty" : 2.09543239, "testnet" : true, "keypoololdest" : 1405815499, "keypoolsize" : 101, "paytxfee" : 0.00000000, "mininput" : 0.00001000, "errors" : "" }
tdrk aren't actual drk's are they?Start your wallet with "testnet=1" in darkcoin.conf
You got it - testnet is actually completely separate blockchain, the coins will never have any value.tdrk aren't actual drk's are they?
Your are right! http://test.explorer.darkcoin.qa/tx...c93d00a831fe52a02ee86c19d4490d9ee6c0fad44c#o1check the tx you sent, I think 1000 tdrk is vout #1 and payout is vout #0
Maybe you can add this "equlto:" and "inmlist:" display from mainnet, too?
I will, and another command rank.Maybe you can add this "equlto:" and "inmlist:" display from mainnet, too?
Seems there is something odd with subsidy detection, too.I will, and another command rank.
Testnet is a separate blockchain, with distinct coins (tDRK). These coins have no value and their only purpose is for testing. You can join the current testnet by downloading one of the most recent RC4 binaries, and putting a "testnet=1" line in the darkcoin.conf. You can also use the normal miners to mine testnet coins, or join a testnet pool.I have a question.
you said:"Note: The blockchain had to be restarted, so all of you will have to collect your test darkcoin again. Although, it's really easy to collect right now, so have at it"
I have some darkcoin.So what's the "test darkcoin"?How to collect?
Evan is admin of this pool and likely sleeping now. I would suggest to create a new account or use testnet nomp pool instead.Cannot cash my coins out of the http://ec2-54-91-161-78.compute-1.amazonaws.com/ pool.
When entering pin to cash out - error saying "cannot send email to this address"
Now my account is locked. Could someone with back end access reset and email me my new pin and fix the email unlock issue.
Username: Stealth923
Thanks!
Sorry for asking this again, isnt the main net blockchain even older? Are we sure this does not create any issues?Nope, the problem was a really old block that wasn't getting accepted by CheckBlock (only on testnet)
Yep, mainnet is older, but testnet has seen more different CheckBlock() implementations and hard forks during its lifespan.Sorry for asking this again, isnt the main net blockchain even older? Are we sure this does not create any issues?
Don't do that, it's counter-productive actually. People doing single thread cpu mining is totally fine and everyone gets their share to work with.I want to help, I can throw 120mhs at amazon test pool for a while, but since thats 10x the network size i don't want to cause a problem. Advice?
Please test this one, font issue should be fixed.Haven't merged the fix to RC4 code yet, will do after breakfastJust downloaded Mac version and it has the previous issue with the addresses font. Though you should know.![]()
http://bamboo.darkcoin.qa/browse/DOD-DRK-48/artifact/QTL/gitian-osx-darkcoin/DarkCoin-Qt.dmg
Subsidy and equlto fixed.Maybe you can add this "equlto:" and "inmlist:" display from mainnet, too?
sentCan someone with excess tDRK send 1k to each of these addresses?
mqJWHUEf1w9i6nGzfrpUWUg2oovwgDSb7V
mu2EV6HqFEDZWdXEKmeNQVGWLxadLPXRAG
Thanks![]()
"account" : "0",
"address" : "mmwGeqnnMBRU6cUTP25gZvGi7fsMVSErQX",
"category" : "send",
"amount" : -1800.00000000,
"fee" : 0.00000000,
"confirmations" : 25,
"blockhash" : "000000003d095e6acc6c315b6513d146f809c9b16de6bf7cac3ba3bb12e5ad87",
"blockindex" : 1,
"blocktime" : 1405863634,
"txid" : "f33778837cf69b56543708c149e08c857ddf8a9f13f12fba4e37386b329b9bb0",
"time" : 1405863390,
"timereceived" : 1405863390
"account" : "",
"fee" : 800.00000000,
"confirmations" : 24,
"blockindex" : 1,
"time" : 1405863634,
"timereceived" : 1405867230
Same here. Will spread tdrk wealth when we get em.Evan is admin of this pool and likely sleeping now.
Maybe it's testing ?check the tx you sent, I think 1000 tdrk is vout #1 and payout is vout #0
2014-07-20 15:29:37 received block 0000000122c236c9a0d2a3d35d00172654d3fab745965ae62cab867c7ea081bc peer=9
2014-07-20 15:29:37 MasternodeConsessus - found a winner
2014-07-20 15:29:37 MasternodeConsessus - strong consessus
2014-07-20 15:29:37 MasternodeConsessus - Masternode payment to OP_DUP OP_HASH160 4371cc819907ca3cdee15a07a61f1894705d6059 OP_EQUALVERIFY OP_CHECKSIG
2014-07-20 15:29:37 CheckBlock() : Couldn't find masternode payment. Found Amount 1 Found Payee 0
2014-07-20 15:29:37 Committing 4 changed transactions to coin database...
2014-07-20 15:29:37 SetBestChain: new best=0000000122c236c9a0d2a3d35d00172654d3fab745965ae62cab867c7ea081bc height=874 log2_work=40.927009 tx=957 date=2014-07-20 15:27:47 progress=0.038752
2014-07-20 15:32:25 received block 000000002defc648b1c4d00707a504e4f50fb53ae2ec32ad189eec9bf0b85224 peer=31
2014-07-20 15:32:25 MasternodeConsessus - found a winner
2014-07-20 15:32:25 MasternodeConsessus - strong consessus
2014-07-20 15:32:25 MasternodeConsessus - Masternode payment to OP_DUP OP_HASH160 4371cc819907ca3cdee15a07a61f1894705d6059 OP_EQUALVERIFY OP_CHECKSIG
2014-07-20 15:32:25 Committing 4 changed transactions to coin database...
2014-07-20 15:32:25 SetBestChain: new best=000000002defc648b1c4d00707a504e4f50fb53ae2ec32ad189eec9bf0b85224 height=875 log2_work=40.929474 tx=958 date=2014-07-20 15:32:20 progress=0.038792
