Testnet: Official Release of Bitcore Libraries and Insight API
Discussion in 'General Discussion' started by snogcel, Sep 29, 2016.
  1. snogcel
    snogcel Guest
    On behalf of the Evolution and Core development teams I'm pleased to announce the release of Bitcore-Dash and Insight API for public testing.
    What is Bitcore?
    Bitcore was released by BitPay in February 2014 and was designed to power blockchain applications and open-sourced to spur blockchain innovation. This project provides a collection of libraries that can be used for either server-side or client-side development, more information about Bitcore is available at www.bitcore.io.
    What is Bitcore-Dash?
    Bitcore-Dash is an example of a naming convention which applies "-dash" to any component of the Bitcore Stack that has been prepared for usage on the dash network. This set of libraries is intended to be the Dash equivalent of Bitcore and is secured by the blockchain-funded X11 hashing library which was completed over the summer.
    Important Notes:
    Please note that Bitcore-Dash requires Dash Core v0.12.1.x. This release has been timed to coincide with "phase two" of 12.1 testing and should only be used on testnet. Also note that it has not yet been released for "livenet" and as such the latest packages have not yet been published to NPM. This allows us the flexibility to default the network settings to "testnet" during this testing phase.
    Insight API Block Explorer
    insight UI (testnet): http://test-insight.dev.dash.org
    insight API (testnet): http://test-insight.dev.dash.org/insight-api-dash/...
    <see insight-api-dash readme for endpoints>
    Bitcore-Dash Repositories:
    bitcore-dash: https://github.com/dashpay/bitcore-dash
    bitcore-lib-dash: https://github.com/dashpay/bitcore-lib-dash
    bitcore-node-dash: https://github.com/dashpay/bitcore-node-dash
    Insight API Repositories:
    insight-api-dash: https://github.com/dashpay/insight-api-dash
    insight-ui-dash: https://github.com/dashpay/insight-ui-dash
    How do I get started?
    Head over to the development branch of Bitcore-Dash: https://github.com/dashpay/bitcore-dash/tree/dev-testnet.
    In summary:
    1) Install Node V4.0.0 using nvm (https://github.com/creationix/nvm)
    2) Install build dependencies: sudo apt-get install build-essential libzmq3-dev
    3) Install bitcore-dash using the "dev-testnet" branch:
    git clone https://github.com/dashpay/bitcore-dash -b dev-testnet
    cd bitcore-dash
    npm install -g
    bitcored
    By default, bitcore-dash will place the dash daemon in ~/.bitcore/data. For this testnet release pre-compiled binaries are being provided through a download script. For more information on the internals of this process please see the "dev-testnet" branch of bitcore-node-dash.
    Disable Automatic Download:
    If you're not using an x86 or x64 Linux operating system (e.g. Raspberry Pi) please note that you'll need to compile the daemon locally and then place it in ~/.bitcore/data. The following commands will download a development branch of Bitcore-Dash which does not automatically download the dash daemon:
    git clone https://github.com/dashpay/bitcore-dash -b dev-nodownload
    cd bitcore-dash
    npm install -g
    bitcored
    Testing:
    Help us find bugs! Help us expand the documentation! Help us expand the feature set! This is a collaborative endeavor so please try it out and post your feedback and questions on this thread.
    Recognitions:
    This work would not have been possible without the contributions of a number of people including but not limited to (and in no particular order):
    @UdjinM6: Dash Core v0.12.1.x modification to support bitcore-node-dash as well as customization to allow for ZMQ InstantSend notifications.
    @QuantumExplorer: Development of x11-hash-js, a 100% native JavaScript X11 hashing library.
    @snogcel: Development of bitcore-dash, bitcore-node-dash, insight-api-dash and others.
    @flare: Repository management, upstream merging and test coverage.
    @moocowmoo: Development of dockerfile-based installation process and management of infrastructure.
    #1 snogcel, Sep 29, 2016
    • Like Like x 16
    • Winner Winner x 1
  2. TaoOfSatoshi
    TaoOfSatoshi Grizzled Member
    Jul 15, 2014
    2,635
    2,590
    Great job to all!
    • Like Like x 1
  3. kot
    kot Well-known Member
    Dash Core Team Foundation Member
    Mar 17, 2015
    681
    1,826
    263
    @snogcel - you rock man!
    Thanks a lot for what you are doing on the backend side of Evolution development!
    • Like Like x 2
    • Agree Agree x 1
  4. ec1warc1
    ec1warc1 Active Member
    Jul 26, 2016
    319
    169
    This is very exciting news. I am on assignment in Cali, Colombia - very busy until Friday, Oct 7. But, soon, I will be looking at this more deeply! Thanks for the work done! Awesome!
    • Like Like x 1
  5. darkzero
    darkzero Member
    Jun 6, 2014
    44
    35
    Should have enough time in the few coming days to install it. Thanks!
    • Like Like x 1
  6. darkzero
    darkzero Member
    Jun 6, 2014
    44
    35
    Well, with latest node bitcored continues to run dashd over and over getting many dashd processes running
    $ ./bitcored
    info: Using config: bitcore-node-dash.json
    info: Starting bitcoind
    info: Starting dash process
    Dash Core server starting
    warn: Dash process unexpectedly exited with code: 0
    warn: Restarting dash child process in 5000ms
    with node 5.0 exits with this error
    $ ./bitcored
    /.npm/lib/node_modules/bitcore-dash/node_modules/bindings/bindings.js:83
      throw e
    Error: Module version mismatch. Expected 47, got 48.
      at Error (native)
      at Object.Module._extensions..node (module.js:450:18)
      at Module.load (module.js:356:32)
      at Function.Module._load (module.js:311:12)
      at Module.require (module.js:366:17)
      at require (module.js:385:17)
      at bindings (/.npm/lib/node_modules/bitcore-dash/node_modules/bindings/bindings.js:76:44)
      at Object.<anonymous> (/.npm/lib/node_modules/bitcore-dash/node_modules/zmq/lib/index.js:6:30)
      at Module._compile (module.js:425:26)
      at Object.Module._extensions..js (module.js:432:10)
    with node 4.0 even worse
    Segmentation fault (core dumped)
    Quite stuck..
  7. snogcel
    snogcel Guest
    @darkzero sorry to hear you're having trouble. A few things to note that I think might help:
    1. bitcored spawns an instance of dashd when it's launched and also monitors it while it's running. Usually that works pretty well, if it trips over itself you can use "top" to view active processes, then use "sudo kill <pid>" (replace <pid> with the process id number).
    2. make sure that you're using nvm - it makes the whole thing much more smoothly and removes OS specific things. Are you using nvm?
    3. when you change node versions you need to rebuild certain things. Along with "npm install" make sure to "npm rebuild".
    In this case, can you try the following?
    nvm install v4.0.0
    nvm use v4.0.0
    log off and log back in to ssh (this enables nvm)
    cd bitcore-dash
    npm rebuild
    npm install -g
    bitcored
    Let me know if that helps at all. I'm assuming you're using Ubuntu?
  8. darkzero
    darkzero Member
    Jun 6, 2014
    44
    35
    @snogcel i'm on Ubuntu 16.04.1 LTS
    1. the problem is that it continues to spwan new instances forever if not interrupted
    2. yes using nvm
    3. the rebuild hint helped
    But still not working, see if the log helps to understand why, thanks!
    $ nvm install v4.0.0
    v4.0.0 is already installed.
    Now using node v4.0.0 (npm v2.14.2)
    $ node --version
    v4.0.0
    /bitcore-dash$ npm --version
    2.14.2
    /bitcore-dash$ npm rebuild
    /bitcore-dash$ npm install -g
    > [email protected] preinstall /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash
    > ./scripts/download
    Downloading dash: http://download.slayer.work//
    npm ERR! Linux 4.1.19-v7+
    npm ERR! argv "/home//.nvm/versions/node/v4.0.0/bin/node" "/home//.nvm/versions/node/v4.0.0/bin/npm" "install" "-g"
    npm ERR! node v4.0.0
    npm ERR! npm v2.14.2
    npm ERR! code ELIFECYCLE
    npm ERR! [email protected] preinstall: `./scripts/download`
    npm ERR! Exit status 22
    npm ERR!
    npm ERR! Failed at the [email protected] preinstall script './scripts/download'.
    npm ERR! This is most likely a problem with the bitcore-node-dash package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! ./scripts/download
    npm ERR! You can get their info via:
    npm ERR! npm owner ls bitcore-node-dash
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR! bitcore-dash/npm-debug.log
    and inside /bitcore-dash/scripts there is not download file
  9. snogcel
    snogcel Guest
    Tnx for the log files @darkzero. It looks like it's getting stuck when attempting to download the binaries, I have a feeling that your .bitcore folder was created as root and as a result it's not able to write to it.
    Can you please try the following command?
    sudo rm -rf ~/.bitcore
    After that try installing again -- if it's still having trouble can you please issue this command and let me know what it does?
    /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/scripts/download
    • Like Like x 1
  10. darkzero
    darkzero Member
    Jun 6, 2014
    44
    35
    @snogcel
    the .bitcore folder is writable
    $ ll ~/
    total 204
    drwxr-xr-x 26 dev dev 4096 Oct 2 15:50 ./
    drwxr-xr-x 3 root root 4096 Jul 17 12:50 ../
    drwxr-xr-x 3 dev dev 4096 Oct 2 12:46 .bitcore/
    the command
    npm install -g
    return the same error.. and the download script
    $ /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/scripts/download
    -bash: /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/scripts/download: No such file or directory
    The path stops at node_modules, somehow nothing has been installed?
    $ ll /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/
    total 12
    drwxr-xr-x 3 dev dev 4096 Oct 3 22:14 ./
    drwxr-xr-x 3 dev dev 4096 Sep 8 2015 ../
    drwxr-xr-x 9 dev dev 4096 Sep 8 2015 npm/
    Question: can i install the whole .nvm .npm and .bitcore on another folder?
    Thanks
  11. snogcel
    snogcel Guest
    @darkzero - thanks for sharing that, to narrow this down a little bit further can you please try running "npm install" (instead of npm install -g)? This will install all the files into the folder you'd originally pulled bitcore-dash into and avoid any global weirdnesses which I think might be the culprit here. Please give that a try and let me know how it goes :)
  12. darkzero
    darkzero Member
    Jun 6, 2014
    44
    35
    @snogcel
    sending install commands again and somehow improved but at last, same error
    $ npm install -g bitcore-dash
    npm WARN deprecated [email protected]: This package is deprecated. Use Array.isArray.
    $ npm install bitcore-lib-dash
    $ npm install -g bitcore-node-dash
    $ npm rebuild
    [email protected] /bitcore-dash/node_modules/bitcore-lib-dash
    [email protected] /bitcore-dash/node_modules/bitcore-lib-dash/node_modules/bn.js
    [email protected] /bitcore-dash/node_modules/bitcore-lib-dash/node_modules/bs58
    [email protected] /bitcore-dash/node_modules/bitcore-lib-dash/node_modules/buffer-compare
    [email protected] /bitcore-dash/node_modules/bitcore-lib-dash/node_modules/elliptic
    [email protected] /bitcore-dash/node_modules/bitcore-lib-dash/node_modules/elliptic/node_modules/brorand
    [email protected] /bitcore-dash/node_modules/bitcore-lib-dash/node_modules/elliptic/node_modules/hash.js
    [email protected] /bitcore-dash/node_modules/bitcore-lib-dash/node_modules/inherits
    [email protected] /bitcore-dash/node_modules/bitcore-lib-dash/node_modules/lodash
    [email protected] /bitcore-dash/node_modules/bitcore-lib-dash/node_modules/sha512
    [email protected] /bitcore-dash/node_modules/bitcore-lib-dash/node_modules/x11-hash-js
    $ npm install -g
    > ./scripts/download
    npm ERR! argv "/home/dev/.nvm/versions/node/v4.0.0/bin/node" "/home/dev/.nvm/versions/node/v4.0.0/bin/npm" "install" "-g"
    npm ERR!
    npm ERR! /bitcore-dash/npm-debug.log
    Sent command as suggested
    $ npm install
    npm WARN deprecated [email protected]: to-iso-string has been deprecated, use @segment/to-iso-string instead.
    npm WARN deprecated [email protected]: Jade has been renamed to pug, please install the latest version of pug instead of jade
    npm WARN deprecated [email protected]: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    > [email protected] preinstall /bitcore-dash/node_modules/bitcore-node-dash
    > ./scripts/download
    npm ERR!
  13. snogcel
    snogcel Guest
    • Agree Agree x 1
  14. snogcel
    snogcel Guest
    As a quick update on this: it turns out the automatic download script is unable to properly detect Raspberry Pi which was causing the errors above. I've added the following bit to the original post for scenarios where the daemon should be compiled locally:
    cd bitcore-dash
    npm install -g
    bitcored
  15. darkzero
    darkzero Member
    Jun 6, 2014
    44
    35
    Hello, here I am again this time on livenet and Rpi.. :rolleyes:
    Well started install bitcore-dash but fails at download
    > [email protected] preinstall /home/dev/.nvm/versions/node/v6.7.0/lib/node_modules/.staging/bitcore-node-dash-242c5ca8
    > ./scripts/download
    Downloading dash: https://bamboo.dash.org/browse/DASHL-DEV/latestSuccessful/artifact/JOB1/gitian-linux-dash-dist//
    ./scripts/download: line 46: $tarball_name: ambiguous redirect
    npm ERR! argv "/home/dev/.nvm/versions/node/v6.7.0/bin/node" "/home/dev/.nvm/versions/node/v6.7.0/bin/npm" "install" "-g" "bitcore-dash"
    npm ERR! node v6.7.0
    npm ERR! npm v3.10.3
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the bitcore-node-dash package,
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs bitcore-node-dash
    npm ERR! Or if that isn't available, you can get their info via:
    So, got the nodownload branch
    git clone https://github.com/dashpay/bitcored-dash -b nodownload
    By runnig bitcored the spawned dashd seems to not be able to open the RPC socket (from debug.log)
    2017-02-09 23:03:23 Binding RPC on address 0.0.0.0 port 9998 failed.
    And bitcored fails to call via RPC and tries to restart the dashd process after few seconds, dashd isn't even running yet. And the loop goes on
    $ bitcored
    [2017-02-09T22:31:05.574Z] info: Using config: /home/dev/.bitcore/bitcore-node-dash.json
    [2017-02-09T22:31:05.592Z] info: Using network: livenet
    [2017-02-09T22:31:05.601Z] info: Starting bitcoind
    [2017-02-09T22:31:05.623Z] info: Using bitcoin config file: /home/dev/.bitcore/data/dash.conf
    [2017-02-09T22:31:05.647Z] info: Starting dash process
    [2017-02-09T22:31:05.814Z] warn: Dash process unexpectedly exited with code: 0
    [2017-02-09T22:31:05.820Z] warn: Restarting dash child process in 5000ms
    [2017-02-09T22:31:10.833Z] info: Using bitcoin config file: /home/dev/.bitcore/data/dash.conf
    [2017-02-09T22:31:10.881Z] warn: Loading block index...
    [2017-02-09T22:31:10.891Z] warn: Stopping existing spawned dash process with pid: 8318
    [2017-02-09T22:31:15.907Z] warn: Loading block index...
    [2017-02-09T22:31:20.901Z] warn: Stopping existing spawned dash process with pid: 8318
    [2017-02-09T22:31:20.920Z] warn: Loading block index...
    [2017-02-09T22:31:25.938Z] warn: Loading block index...
    [2017-02-09T22:31:30.909Z] warn: Stopping existing spawned dash process with pid: 8318
    [2017-02-09T22:31:30.951Z] warn: Loading block index...
    ^C[2017-02-09T22:31:33.132Z] info: Beginning shutdown
    [2017-02-09T22:31:33.136Z] info: Stopping insight-ui-dash (not started)
    [2017-02-09T22:31:33.143Z] info: Stopping insight-api-dash (not started)
    [2017-02-09T22:31:33.145Z] info: Stopping web (not started)
    [2017-02-09T22:31:33.147Z] info: Stopping bitcoind
    [2017-02-09T22:31:33.150Z] info: Halted
    The file bitcore-node-dash.json is as follows
    $ more bitcore-node-dash.json
    "network": "livenet",
    "port": 3001,
    "rpcport": 9998,
    "services": [
    "bitcoind",
    "web",
    "insight-api-dash",
    "insight-ui-dash"
    "servicesConfig": {
    "bitcoind": {
    "spawn": {
    "datadir": "/home/dev/.bitcore/data",
    "exec": "/home/dev/.bitcore/data/dashd"
    Note that in /home/dev/.bitcore/data/dashd there is a working instance of dashd if run alone
    Then tried to modify spawn in connect, but it fails because bitcored tries to connect to port 8332 o_O
    Can't find in *.js that port..
    "port": 3001,
    "rpcport": 9998,
    "services": [
    "bitcoind",
    "web",
    "insight-api-dash",
    "insight-ui-dash"
    "servicesConfig": {
    "bitcoind": {
    "connect": {
    "rpchost": "127.0.0.1",
    "rpcport": 9998,
    "port": 9999,
    "rpcuser": "dash",
    "rpcpassword": "local321",
    "zmqpubrawtx": "tcp://127.0.0.1:28332"
    $ bitcored
    [2017-02-09T22:38:16.004Z] info: Using config: /home/dev/.bitcore/bitcore-node-dash.json
    [2017-02-09T22:38:16.023Z] info: Using network: livenet
    [2017-02-09T22:38:16.035Z] info: Starting bitcoind
    [2017-02-09T22:43:13.023Z] error: Failed to start services
    [2017-02-09T22:43:13.038Z] error: RPCError: Bitcoin JSON-RPC: Request Error: connect ECONNREFUSED 127.0.0.1:8332
    at Bitcoin._wrapRPCError (/home/dev/.nvm/versions/node/v6.7.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/lib/services/bitcoind.js:468:13)
    at /home/dev/.nvm/versions/node/v6.7.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/lib/services/bitcoind.js:820:28
    at ClientRequest.<anonymous> (/home/dev/.nvm/versions/node/v6.7.0/lib/node_modules/bitcore-dash/node_modules/bitcoind-rpc-dash/lib/index.js:116:7)
    at emitOne (events.js:96:13)
    at ClientRequest.emit (events.js:188:7)
    at Socket.socketErrorListener (_http_client.js:308:9)
    at Socket.emit (events.js:188:7)
    at emitErrorNT (net.js:1271:8)
    at _combinedTickCallback (internal/process/next_tick.js:74:11)
    [2017-02-09T22:43:13.048Z] info: Beginning shutdown
    [2017-02-09T22:43:13.053Z] info: Stopping insight-ui-dash (not started)
    [2017-02-09T22:43:13.056Z] info: Stopping insight-api-dash (not started)
    [2017-02-09T22:43:13.060Z] info: Stopping web (not started)
    [2017-02-09T22:43:13.061Z] info: Stopping bitcoind
    [2017-02-09T22:43:13.064Z] info: Halted
    Any hint? Thanks
  16. snogcel
    snogcel Guest
    hey @darkzero it's been awhile :)
    It looks like this problem is at least partially related to the node version you're using,
    Please try the following:
    Edit: just re-read your message, to avoid the auto download... :)
    nvm install v4.0.0
    nvm use v4.0.0
    git clone https://github.com/dashpay/bitcore-dash -b nodownload
    cd bitcore-dash
    npm install -g
    At that point you should be able to launch the daemon with the following command:
    bitcored
    Please give it a try and let me know how it goes!
    #17 snogcel, Feb 9, 2017
  17. darkzero
    darkzero Member
    Jun 6, 2014
    44
    35
    @snogcel well it didn't work. It seems that the config isn't really read :rolleyes:
    In fact I modified the values in some .js and didn't get error at same place
    $ npm install -g
    > ./scripts/download --skip-bitcoin-download
    > [email protected] install /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/utf-8-validate
    > node-gyp rebuild
    make: Entering directory '/home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/utf-8-validate/build'
    CXX(target) Release/obj.target/validation/src/validation.o
    SOLINK_MODULE(target) Release/obj.target/validation.node
    COPY Release/validation.node
    make: Leaving directory '/home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/utf-8-validate/build'
    > [email protected] install /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/bufferutil
    > node-gyp rebuild
    make: Entering directory '/home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/bufferutil/build'
    CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
    SOLINK_MODULE(target) Release/obj.target/bufferutil.node
    COPY Release/bufferutil.node
    make: Leaving directory '/home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/bufferutil/build'
    > [email protected] install /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/zmq
    > node-gyp rebuild
    make: Entering directory '/home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/zmq/build'
    CXX(target) Release/obj.target/zmq/binding.o
    SOLINK_MODULE(target) Release/obj.target/zmq.node
    COPY Release/zmq.node
    make: Leaving directory '/home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/zmq/build'
    /home/dev/.nvm/versions/node/v4.0.0/bin/bitcored -> /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/bin/bitcored
    /home/dev/.nvm/versions/node/v4.0.0/bin/bitcore -> /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/bin/bitcore
    [email protected] /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash
    ├── [email protected]
    ├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
    ├── [email protected] ([email protected]0, [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
    └── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
    $ bitcored
    [2017-02-10T11:22:42.156Z] info: Using config: /home/dev/.bitcore/bitcore-node-dash.json
    [2017-02-10T11:22:42.172Z] info: Using network: livenet
    [2017-02-10T11:22:42.182Z] info: Starting bitcoind
    [2017-02-10T11:27:38.470Z] error: Failed to start services
    [2017-02-10T11:27:38.488Z] error: RPCError: Bitcoin JSON-RPC: Request Error: connect ECONNREFUSED 127.0.0.1:8332
    at Bitcoin._wrapRPCError (/home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/lib/services/bitcoind.js:466:13)
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/lib/services/bitcoind.js:818:28
    at ClientRequest.<anonymous> (/home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/bitcoind-rpc-dash/lib/index.js:116:7)
    at emitOne (events.js:77:13)
    at ClientRequest.emit (events.js:169:7)
    at Socket.socketErrorListener (_http_client.js:259:9)
    at Socket.emit (events.js:169:7)
    at emitErrorNT (net.js:1250:8)
    at doNTCallback2 (node.js:429:9)
    [2017-02-10T11:27:38.503Z] info: Beginning shutdown
    [2017-02-10T11:27:38.508Z] info: Stopping insight-ui-dash (not started)
    [2017-02-10T11:27:38.517Z] info: Stopping insight-api-dash (not started)
    [2017-02-10T11:27:38.521Z] info: Stopping web (not started)
    [2017-02-10T11:27:38.522Z] info: Stopping bitcoind
    [2017-02-10T11:27:38.525Z] info: Halted
    Modified user, pass, port here:
    $ bitcored
    [2017-02-10T12:01:25.760Z] info: Stopping insight-ui-dash (not started)
    [2017-02-10T12:01:25.763Z] error: uncaught exception: [TypeError: Address must be a string!]
    [2017-02-10T12:01:25.767Z] error: TypeError: Address must be a string!
    at TypeError (native)
    at Socket.connect (/home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/zmq/lib/index.js:501:13)
    at Bitcoin._initZmqSubSocket (/home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/lib/services/bitcoind.js:780:21)
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/lib/services/bitcoind.js:991:10
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/async/lib/async.js:676:51
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/async/lib/async.js:726:13
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/async/lib/async.js:52:16
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/async/lib/async.js:264:21
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/async/lib/async.js:44:16
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/async/lib/async.js:723:17
    [2017-02-10T12:01:25.769Z] info: Beginning shutdown
    Again error, the object that holds config values seems empty, modifying this .js went through
    nano /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/lib/services/bitcoind.js
    $ bitcored
    [2017-02-10T12:23:16.377Z] info: Using config: /home/dev/.bitcore/bitcore-node-dash.json
    [2017-02-10T12:23:16.392Z] info: Using network: livenet
    [2017-02-10T12:23:16.401Z] info: Starting bitcoind
    [2017-02-10T12:23:16.793Z] error: Failed to start services
    [2017-02-10T12:23:16.806Z] error: Error: Bitcoin configuration options "spawn" or "connect" are expected
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/lib/services/bitcoind.js:1040:23
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/async/lib/async.js:269:32
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/async/lib/async.js:167:37
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/lib/services/bitcoind.js:1029:11
    at /home/dev/.nvm/versions/node/v4.0.0/lib/node_modules/bitcore-dash/node_modules/bitcore-node-dash/node_modules/async/lib/async.js:361:13
    Again, config has those values, but aren't they read? o_O
    "port": 3001,
    "rpcport": 9998,
    "services": [
    "bitcoind",
    "web",
    "insight-api-dash",
    "insight-ui-dash"
    "servicesConfig": {
    "bitcoind": {
    "connect": {
    "rpcport": 9998,
    "rpcuser": "dash",
    "zmqpubrawtx": "tcp://127.0.0.1:28332",
    "zmqpubrawtxlock": "tcp://127.0.0.1:28332",
    "zmqpubhashblock": "tcp://127.0.0.1:28332"
    I'm almost there.. :)
  18. snogcel
    snogcel Guest
    So close! I think the issue now relates to your bitcore-node-dash.json file, there's some stuff in there which is typically included in a "default installation". Please see below for a reference copy:
      "port": 3001,
      "services": [
        "bitcoind",
        "web",
        "insight-api-dash",
        "insight-ui-dash"
      "servicesConfig": {
        "bitcoind": {
          "spawn": {
    You may notice that none of the RPC related settings are included in this file, I'd suggest leaving these at their defaults or if you do need to change anything to use the dash.conf that's stored in ~/.bitcore/data/dash.conf. I think once you get this cleared up we should be in good shape, just let me know :)
  19. darkzero
    darkzero Member
    Jun 6, 2014
    44
    35
    @snogcel well, it's up and running at http://212.47.247.1:3001/
    (API available at default url http://212.47.247.1:3001/api/ )
    It's been setup as a service with a script for systemd but I can't find the log anymore (before it was in the console). Do you know how to configure it? Never mind, I found the logs, forgot that were in the journal..
    I may leave it running if it's useful.
    Cheers
    EDIT: was looking to install also an electrum server but i found that needs many resources, is it true also for dash?
    Does anybody knows about ElectrumX? https://github.com/kyuupichan/electrumx
    Seems to have support for dash also
    #20 darkzero, Feb 28, 2017
    • Like Like x 2
  20. Skrutch
    Skrutch Guest
    1., if I login with SSH (root), I run bitcore-node-dash start , it's start to work, then if close terminal, Node is down. how I can run it correctly..?
    2. If can't run bitcore-node-dash start, see this ouput..., but problem with reboot server... Try to kill process, but can't fix.
    Why?
    [​IMG]
    This is normal?
    [​IMG]
    [​IMG]
    But "insight" is run I think well, but want to fix all critical warning...
    P.S. snogcel https://github.com/dashevo/bitcore-node-dash/issues/21
Share This Page
