So someone gave me an Antminer S1...
Discussion in 'Mining' started by pbleak, Jan 23, 2015.
  1. pbleak
    pbleak Active Member
    May 15, 2014
    399
    172
    A Bitcoin miner I know only through a meetup group has donated an Antminer S1 to me (he said he could only get 20e on ebay for it so just passed it on).
    He suggested a Corsair power supply...any idea what one is best or where I could find a cheap one (from Europe, not the US).
    Also what exactly do you guys think I should do with it...the mining/electricity ratio means it is unprofitable for Bitcoin but it also seems a shame to just let the thing sit there all sad and doing nothing.
    I'm also totally keeping it in general terms as 'just a cool thing to have' so no selling on.
  2. stonehedge
    stonehedge Well-known Member
    Jul 31, 2014
    696
    333
    233
    1) Fire it up and solo mine bitcoins. 1 in 500,000 that you'll hit a block at this difficulty but better odds than some lotteries!
    2) Fire it up and point it at Xpool.ca and earn some Darkcoin.
  3. pbleak
    May 15, 2014
    399
    172
    I'm thinking of mining DRK for sure. I need to sit down and work out how many coins 180GHS will pull in. The main worry is, of course electricity. Any tips on how people deal with this?
  4. ourlink
    ourlink Well-known Member
    Jun 9, 2014
    237
    65
    188
    I have two bitcoin miners setting in the corner of my office.... 1 KNC Jupiter @ 650 GHs and 1 Cointerra Terraminer @ 1.6 Ths. I don't run either of them anymore because the electricity costs way more that they will ever produce again in mining profits. Your friend was wise to just get rid of the ant miner because they are sometimes to tempting to not power them back up and mine with them! Good Luck and monitor your power bill steadily...
  5. pbleak
    May 15, 2014
    399
    172
    I think he just knew I'd like to have one. He has a few racks of decent miners in his setup so to him it might have been like just handing someone a toy. What I might do is fire it up and just see how it works from time to time as an experience.
    I am curious as to whether there are no alt coins you could mine with those machines that would make a profit? (DRK or otherwise)?
  6. ourlink
    Jun 9, 2014
    237
    65
    188
    ASICS are "Application Specific" so if they are designed for bitcoin you can mine only bitcoin... You can mine in a pool that converts your bitcoin to some other coin, but in the end you are still just mining bitcoin. With bitcoin's difficulty level even my ~2.5 Ths isn't profitable... :sad:
  7. thelonecrouton
    thelonecrouton Well-known Member
    Apr 15, 2014
    1,135
    813
    You can mine any SHA256 coin with it, but none of them are profitable unless you have free electricity, and even then you're talking pennies a day.
  8. pbleak
    May 15, 2014
    399
    172
    I think I may just have it as a party-piece so: 'look, a Bitcoin miner.' 'Ohhhh, it is on?' 'No, it's a retired miner.'
  9. stonehedge
    Jul 31, 2014
    696
    333
    233
    With apologies for the crudeness, I believe that Startcoin and Wankcoin are both relatively less unprofitable than other sha256d alt coins.
  10. Sub-Ether
    Sub-Ether Well-known Member
    Mar 31, 2014
    1,516
    1,254
    I checked the spec of the antminer and it's 360 watts at 12 volts so if watts=volts*amps, you have 30 amps with 3 times 12 volt rails to find.
    I suggest not buying a new power supply, you can power it off an old PSU as long as its over about 400 watts in total(check label spec on side). I have a 500 watt that is speced at 36 amps for 12 volts so that would give some headroom, use as many separate 12 volt (yellow) wires from the PSU as possible.
    It would probably be ok to use really old 250 watts atx power supplies to power 10 amps each, so 1 for each 12 volt rail, but you would need 3 of them in total(I have not tried that, there is a chance of cross railing it but should be ok,just make sure you get the yellow(s) 12 volts correct way round and connect all 3 blacks together to form a fixed zero volts rail)
    And short the only green wire on the big connector to any adjacent black to start the PSU and take the 12 volts from the yellow(2 yellows on newer atx) at the back right..
    [​IMG]
    Any black will do from the connector to form the common zero voltage rail for all 3 PSU's.
    • Like Like x 1
  11. Miner237
    Miner237 Well-known Member
    May 28, 2014
    506
    223
    213
    Mine some MazaCoin with it since it's going to the moon!
    Maza.CryptoADHD.com
    • Like Like x 2
  12. pbleak
    May 15, 2014
    399
    172
    Thanks, this is exactly the kind of thing I was hoping/thinking of doing. Will report back on how it goes!
    • Like Like x 1
  13. pbleak
    May 15, 2014
    399
    172
    My antminer arrives tomorrow. Will be funny staring at it and pondering what to do. Power first and then some reading!
    • Like Like x 1
  14. pbleak
    May 15, 2014
    399
    172
    OK, it's here can anybody recommend here to buy old PSUs - as mentioned above - since I have none about the place. I'm in Europe. Not sure what brand to get, but I'm sure people round here know this stuff inside out.
  15. splawik21
    splawik21 Grizzled Member
    Dash Core Team Foundation Member Dash Support Group Moderator
    Apr 8, 2014
    1,912
    1,273
  16. Partimebiz
    Partimebiz New Member
    Oct 7, 2017
    hi i'm new in bitcoin but i want to ask about antminer S1 is it can be changed to be other than bitcoin miner?
  17. Partimebiz
    Oct 7, 2017
    I have 6 units of antamina S1 which is not used anymore, is it suitable for use other than bitcoin miner? I hope anyone will answer my question .. sorry this is because I am new to this machine
  18. Partimebiz
    Oct 7, 2017
    hi I want to ask anyone who knows, is it still appropriate for me to mine bitcoin or other suitable coin?
  19. ricardoanywhere
    ricardoanywhere New Member
    Dec 24, 2017
    Hi dude:
    I recommend you to buy a cheapest used server PSU (Power Supply Unit) that could supply power for up to two S1/S3 ASIC miners.
    Like an example of refered server PSU:
    -HP Z800 PSU
    -IBM x3650 or 3655 (835Watts)
    -Delta DPS-835AB
    -Artesyn 7001138-Y000
    Any server PSU must have at less ... 12.0V * 60A = 720Watts (this value is the double of S1 power demand of 360 watts)
    Consult some web pages/online videos like tutorials "how to do" or contact to a technician people (from your friend list first) to make the adaptation job. I have not permited to use link here to refere specific help to you because I am a newcommer here.
    If anybody have not in use bitcoin miners setting in any place of his office or home and want to donate it, I whish I would to receive. It shall be a great help to me. Thank a lot in advance.
    "The distance between your dreams and reality is called action"
    #19 ricardoanywhere, Dec 24, 2017
  20. Ftoole
    Ftoole Member
    Aug 20, 2017
    132
    27
    78
    • Like Like x 1
  21. Raja arun pratap singh
    Jan 29, 2018
    Hi I am new to this mining thing and does not have proper hardware for mining but I made something of my own my mining project is for helping some one who needs it I have free electricity if any one wants to donate asic miners plz contact me on my mail [email protected]
