Reward Per Block
bhkien
Through this https://bitinfocharts.com/darkcoin/
I found that the rewards per block was increased up to 8.38 Dash.
Anyone please explain me:
Does it means the fewer miners the higher rewards per block? And how about max coins? Will the max coins can be much more higher than 22 millions Dashs?
Thank you,
The block rewards are dynamic based of the diff. Once it goes under ~3k diff... the block reward increases a bit and the lower the diff goes... the bigger block reward... My pool has gotten 11+ DASH blocks before...
Thanks, but how about max coins?
Total coin output is reduced by 7% per year until around the year 2150 when new coins will stop being minted. Since difficulty auto-adjusts you can expect coin minting to approach teh expected mean pretty closely until that time.
When blocks stop generating new coins, miners will be paid by TX fees.
Pablo.
