Public key form private key
Discussion in 'Daemon and QT Wallet Support' started by Marian, Mar 22, 2017.
  1. Marian
    Marian New Member
    Mar 21, 2017
    12
    Hello
    How can I get a public key from a private one? I need to do it in Java, but rpc procedure is ok as well.
    • Like Like x 1
  2. flare
    flare Administrator
    Dash Core Team Moderator
    May 18, 2014
    2,287
    2,406
  3. Bertrand256
    Bertrand256 Active Member
    Feb 13, 2017
    228
    272
    123
    Dash Address:
    XwZzf7yqYoUBnDFqE7r3zuNmpwKo1CYLMC
    Hi, As far as I know, algorithm to convert priv to pub in Dash is exactly the same as for Bitcoin and is based on Elliptic Curve multiplication. It is well described in Andreas Antonopolous book: https://github.com/bitcoinbook/bitcoinbook/blob/develop/ch04.asciidoc#public-keys
    In turn, the conversion public key to it's Dash address is a bit different, but only in that, that it uses a different version prefix (76 instead of 00).
    I think, that for priv->pub conversion you can simply use some existing Java bitcoin library .
    • Agree Agree x 1
    • Useful Useful x 1
  4. Marian
    Marian New Member
    Mar 21, 2017
    12
    Thank you, conversion from public key to Dash address was easy to made by changing bitcoinJ library.
    I still have a small problem with checking if private key if from Dash world. There is a parameter called "dumpedPrivateKeyHeader" in Bitcoin witch needs to be set to 128 in order to confirm that it is private bitcoin key. When I try to guess that parameter for Dash, number 204 seems to work, can someone confirm that?
  5. UdjinM6
    UdjinM6 Official Dash Dev
    3,637
    3,536
    Yes, https://github.com/dashpay/dash/blob/master/src/chainparams.cpp#L140
    • Like Like x 1
