P2Pool Error
DrkMiner
204
63
Hi,
I'm having a problem with my P2pool.
1) Memory usage has increased and with time it keeps using more. Could it be memory leakage? (Every update seams to use more memory).
2) pool crashes:
Error while calling getinfo:
2014-09-25 16:40:56.496340 > Traceback (most recent call last):
2014-09-25 16:40:56.496591 > Failure: twisted.internet.error.ConnectBindError: Couldn't bind: 24: Too many open files
darkcoind is up no problem with getinfo command.
What is the "Too many open file"? I'm using the latest P2Pool: 59502b0-dirty
With the previous P2pool script I had no problems.
Server reboot fixed the problem.
Edit: looks like server open file issue.
what file size do you recommend for p2pool?
Thanks!
