Newbie Miner & Pool Questions
h123
1st off, thanks to everyone reading & replying.
Never mined any coins before, so this is all pretty new.
After a bunch of trial and error with miners (the sg miner listed here did not seem to work for me nomatter what) I came across ccminer that supports x11. I managed to get it working, I think:
C:\Users\C\Downloads\ccminer-1.0-windows-new\ccminer-1.0-windows-new\x86>ccminer
35.exe --algo=x11 -o stratum+tcp://drk.coinmine.pl:6090 -u yourworker.1 -p passw
ord
*** ccMiner for nVidia GPUs by Christian Buchner and Christian H. ***
This is version 1.0 (beta)
based on pooler-cpuminer 2.3.2 (c) 2010 Jeff Garzik, 2012 pooler
based on pooler-cpuminer extension for HVC from
[2015-01-26 12:25:10] 1 miner threads started, using 'x11' algorithm.
[2015-01-26 12:25:10] Starting Stratum on stratum+tcp://drk.coinmine.pl:6090
[2015-01-26 12:25:12] thread 0: 1048577 hashes, 847.63 khash/s
[2015-01-26 12:26:06] thread 0: 51380225 hashes, 958.60 khash/s
Question 1: Is there another miner I should be using or is this one "acceptable"?
Question 2: What pool should I join? I've looked around and many don't seem to be operating anymore or I couldn't sign up for some reason. I guess I'd like to join a p2p pool?
Question 3: All I need to do is edit this [stratum+tcp://drk.coinmine.pl:6090 -u yourworker.1 -p password] correct? Is this in another file or can I just type it in the command line?
Hi
what gpu do you have?
Use darkcointalk pool ;)
I'll come home in 4 hours and will paste all you have to do.
Hi
Actually I am using darkcoin.miningpoolhub -- any reason to switch to darkcoin pool?
I upgraded to v1.2 of ccMiner; getting higher hashrates. I have a crappy GPU but I didn't pay for it and electricity is free. it has 4 GB of memory, so maybe there are some ways to optimize it?
What gpu do you have?
Yes change the pool to decentralise the nethash!
Where you mine now they have ~30% of all hash. Switch to darkcointalk.org pool ok?
