Mining power requirements?
Discussion in 'Mining' started by the_darkness, Mar 27, 2014.
  1. the_darkness
    the_darkness New Member
    Mar 22, 2014
    33
    Hey folks, has anybody actually tested power consumption of X11 versus Scrypt etc. on the same rig? I'm interested in doing some back of the envelope calculations but don't have one of those fancy watt-counting plugs that some miners have. Ideally I'd be interested in the power draw on different coins using the same underlying hardware.
  2. mahowi
    mahowi Member
    Mar 13, 2014
    49
    7
    My rig with 2 HD 7950's and AMD FX-6300 mining on 5 cores uses ~400 Watt. On scrypt it consumes ~650W without using the CPU.
    So with CPU on idle it's ~300W for X11 against 650W on scrypt. With energy costs of 0,28 €/kWh (~0.38 $/kWh) this really makes a difference.
  3. the_darkness
    Mar 22, 2014
    33
    Wow that's an amazing savings, even more than I had expected from the accounts online. Definitely puts X11 in a good light. Thanks for the real world numbers!
  4. ErrorId
    ErrorId Member
    Mar 9, 2014
    158
    41
    Holy crap you have expensive electricity.
  5. mahowi
    mahowi Member
    Mar 13, 2014
    49
    7
    Yes. :confused: Energy is quite expensive here in Germany.
