Masternode VPS minimum specs
daddeo
26
With the constantly evolving tech and refinement of DRK, would the following VPS specs be adequate for hosting a masternode or two? Thanks in advance.
  • 2 GB Guaranteed RAM
  • 2 GB vSwap RAM
  • 100 GB SSD RAID-10
  • 4 IP Addresses
  • 3 TB Bandwidth
  • 100 Mbps Network Speed
3,639
3,537
I'm running MN on 512mb ram, 1gb swap, 20gb ssd, 1tb bandwidth. No problems so far. The specs you mentioned would be enough for 4 MN I guess.
Reactions: daddeo
daddeo
26
Thank you for taking the time to answer my question.
Now, get back to making this the best coin of 2015! :tongue:
No but seriously, thank you sir.
Reactions: UdjinM6
ErrorId
158
41
Canada
  • 2 GB vSwap RAM
  • 4 IP Addresses
  • 3 TB Bandwidth
I think I know which provider that is and you can do better. Go check out lowendbox and/or lowendtalk. The lowest container I've heard running a MN was 128 ram / 128 swap.
Reactions: daddeo
daddeo
26
I found this one on lowendbox. But now that I know I can get by with somewhat lesser specs, I'll keep shopping for a better deal. Thanks.
Edit: It is only $4/month which I thought was a decent find. Especially with 4 IP addresses.
