SuchDash
I've been looking into masternodes and would like to double check that I understood things correctly. Are these points correct?
* A masternode is software that needs to always be online and is typically run on a VPS
* The masternode software itself does not have a wallet or access to a wallet (ie having the private key of one)
* In your wallet with 1000 dash, you enter info that links your masetrnode to it
* The wallet with 1000 dash, after initial setup, does not need to remain online for the masternode to function
