Hello friends, are there future plans to enable users to set up a masternode in the qt wallet? An easy way to set it up?
Thank you
Thank you
i doubt it tbhHello friends, are there future plans to enable users to set up a masternode in the qt wallet? An easy way to set it up?
Thank you
https://dash-news.de/dashtv/#value=1000I could figure it out. One question brother, how much does each masternode pull in terms of DASH per day?
Thank you for the quick reply.
alter draengler ...
https://dash-news.de/dashtv/#value=10000So running 10 Masternodes would generate me over $1500 USD per month?
Depends on your line at home - if you have a static IP you can run your masternode at home.is using a service such as Node40 worth it? - am I better off running my own node at home?
If you own a full node (aka 1000 Dash) the service is trustless: You never expose the private key of your coins, you just sign a message with it.Am I trusting that one of these services wont run off with my masternode?
No it will not. No hosting service puts your investment on risk.So running a node with a service like Node40 will not put my investment at risk?
Aren't you more concerned about the "Dash killer" you identified yourself back in June?Am I trusting that one of these services wont run off with my masternode?
no it will notSo running a node with a service like Node40 will not put my investment at risk?
Node40 takes a huge chunk of your payments all in the name of being too lazy to learn a little common sense that anyone should be able to do in this day and age.is using a service such as Node40 worth it? - am I better off running my own node at home?
Let me help u. I was a noob a few months ago. Tried a few options, then did some more research.Im not sure, what youre saying. I am a new DASH user in need of help. That is all that matters right now.
This is basic math... An 8 year old should be able to figure it out in 60 seconds or less.Anyone know what will be the ROE when we reach 5000 masternodes?
I use dashninja's per-day data to multiply by exchange rate. Then I can take that number as daily, and multiply is by 1, 7, 30, or 365... Easier. More flexible.365÷8,68(payment cycle)×1,94=~8.15% ROI
