Masternode Open Ports
Dominic
The default firewall policy on my Masternode is to drop all inbound packets, except ports 22, 80, 443 and 9999.
If I run the command "./dash-cli getinfo" with the firewall off I get the required output.
The same command with the firewall on returns the error "couldn't connect to server"
Is there a definite list of ports required for a Masternode?
Many thanks.
Masternode actually only needs port 9999. I would suggest closing the others if this is your cool wallet and you have a lot of coins.
Many thanks.
dash-cli uses 9998 for rpc port but it should be using localhost by default - make sure you have localhost connections allowed.
22 is for ssh, so if this was a remote one I would definitely keep it open :)
Thanks for all the feedback.
I've added port 9998 TCP and UDP. It still doesn't work. If I change the INPUT policy to ACCEPT it works. I haven't specified any restrictions by IP address, these should include localhost?
Any iptable experts?
Chain INPUT (policy DROP)
target prot opt source destination
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:22
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:80
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:9999
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 state RELATED,ESTABLISHED
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:443
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:9998
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:9998
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp spt:9998
