Masternode not recieving payments.
Myshadow
Shows up here, http://drk.poolhash.org/darksend.html but is one of the nodes without a TXhash.
listtransactions shows the following but no others:
"account" : "",
"address" : "Xo84kNevt7eBcvz6k4WbjuEbu31fdzMYki",
"category" : "receive",
"amount" : 1000.00000000,
"confirmations" : 352,
"blockhash" : "00000000000fe04993169d10a3a11a8cecbfb3ba9c4dc5401d18ccf7af84f8f9",
"blockindex" : 1,
"blocktime" : 1401878178,
"txid" : "3fd2050846c415ee039ee047a0d97e59def783073820a65c92f0266790df8d18",
"time" : 1401878178,
"timereceived" : 1401878308
Anyone have any ideas why its not recieving anything and the TX hash doesn't show up?
Cheers!
awesome :) that'd be why, thanks brilliantrocket. so the TX hash missing isn't relevant then? thought it was a bit wierd thats all.
If it says "YES/YES" you should be fine. It might be a bug at the website you mentioned.
does darkcoind masternode debug say "successfully started masternode"?
Well that is very odd. You didnt receive it on an address 0. should not be able to authorise the node.
It seems ok now looking at the list... Was probably something to do with incoming ports (hadn't enabled port 9999). I guess i'll find out after the 20th if its working as intended :)
