Lost Darksend Balance after update to 0.11.0.10
mjsrs
Hi,
After updating my wallet to version 0.11.0.10 darksend balance is "0.00 DRK" and it was "1.00 DRK" before.
What's wrong?
OS: Windows 7
1) What version are you upgraded from?
2) Did you increase number of rounds?
hmmm... ok.. check number of rounds in Coin Control on Send tab (enable it first - Preferences...->Wallet->Expert->Enable coin control features)
The reason for this could be rounds calculation algorithm changes due to changed denomination method (pre-mix now) so I guess you'll see 7 rounds there.
Maybe my log and a print screen can give you any clue, because I don't have any.
log:
https://drive.google.com/file/d/0Byx-PUMKCNDxQmhubVRvVnloNWs/view?usp=sharing
coin control print screen:
https://drive.google.com/file/d/0Byx-PUMKCNDxRHhqVFBtUldjenM/view?usp=sharing
Let me know if you reach any conclusion
Thanks
It seems you have 1.1 DRK anonymized at 7 rounds. If you go to Settings\Options , change "Darksend rounds to use" to 7, you might see your DS coins show up.
Awesome, changed "Darsend rounds to use" to 7 and the coins are there again.
As the "issue" is solved I'm going to delete the shared files.
Thanks a lot for the help!
updated to v0.11.0.12 and darksend balance is not there again. Took a look on "Coin Control Address Selection" and where there was 7 rounds of Darksend Rounds now it's n/a.
and by the way, it crashed on the first start
updated to v0.11.0.12 and darksend balance is not there again. Toke a look on "Coin Control Address Selection" and where there was 7 rounds of Darksend Rounds now it's n/a.
Yes, new version has this
- Implemented DarkSend convertability
since 11.0.11 which brought new denominations amounts. So it doesn't recognize DS balance from older versions now and you have to remix it, sorry.
