Location of blockchain files
JustADude
Hi guys!
I had an old wallet and so with help from this forum I downloaded the client again, and the blockchain and retreived the dash on my Apple computer.
I then transferred the dash to a marketplace so I don't need the large files on my computer anymore.
How do I do a clean uninstall (including the blockchain etc) on my Macbook ?
Thanks!
To uninstall Dash Core, just drag it from your Applications folder into the Trash.
To uninstall the associated user data (blockchain, wallet, config, etc.), you can delete the data folder. This will result in total and unrecoverable data loss, including any remaining Dash. On macOS, the folder is located in "~/Library/Application Support/", you can get there by pressing Shift + Command + G, type "~/Library/Application Support", then delete the DashCore folder.
