ponysauce
Hey,
I made a dash wallet in late 2015 that was on a hard drive that crashed. I am 90% positive this is the correct wallet.dat file, however, I backed up this wallet.dat before generating the masternode privkey. Unfortunately, when I went to restore my wallet from my wallet.dat file, it did not show any of the coins from the masternode address.
I'm wondering if:
1) There's something else I need to do to get this masternode private key. Are masternode private keys different, such that I may need to run "generate masternode private key" in this wallet a bunch of times to recover these coins? I'm willing to do it -- does this have to do with a deterministic wallet? (I don't really know what any of this means).
2) Am I crazy? Did I create a new wallet and forget to back it up? Is this, most likely, the wrong wallet.dat file?
3) I haven't tried a recovery since mid 2017. Is there anything new in the Dash core that might re-index these address better?
In the event that #1 is true, I might have the computing power, patience, and time needed to re-generate these keys, if necessary / reasonably possible. Basically, I have like 4 laptops and 16 GB of memory that I'm not using. If I can run this experiment and find success, maybe my results will help someone out in the future who has a similar problem.
You can view more info about this problem, including the addresses that hold the coin, here:
https://www.dash.org/forum/threads/lost-masternode-conf-file.9800/
https://explorer.dash.org/address/XqgKnCqM6S6F8NrkGLCkoTvV9b17SNdrcL
Thank you for any info to help me figure this out! I'm not just looking for a solution, help is helpful too!
I'm wondering if:
