hows is payout calculated?
Discussion in 'Masternode Questions and Help.' started by eerygarden, Mar 13, 2017.
  1. eerygarden
    eerygarden New Member
    Feb 13, 2017
    31
    Hi. How does the protocol calculate and distribute the block reward payouts for each masternode? I know that a MN is paid 45% every 6-7 days but how does the network keep track of how long each MN has been active for and are DASH 'added to a pile' before distributing every 6-7 days? I trust that nobody is in charge of that pile before it is sent, but I'd like to understand the technical side to this question.
  2. UdjinM6
    UdjinM6 Official Dash Dev
    Dash Core Team Moderator
    3,637
    3,536
    There is no pile of DASH, each MN simply stays in queue for a payout and when it's time MN gets its share of block reward.
  3. eerygarden
    Feb 13, 2017
    31
    doesn't each new block create a block reward? If it stays in a queue do miners get paid every 6-7 days also?
  4. crowning
    crowning Well-known Member
    May 29, 2014
    1,428
    2,005
    Blocks are created (roughly) every 150 seconds, and 45 % of the block-reward goes to the miners, 45% to the Masternodes. Nothing is piled.
    Which(!) Masternode gets the reward for THIS block is determined by it's position in the Masternode queue.
    When you start a new Masternode it ends at the end of the queue, and it needs (with the current number of Masternodes) about 7 days until it arrives at the top of the queue and gets paid.
    • Like Like x 2
  5. eerygarden
    Feb 13, 2017
    31
    Ahhhh. Understood!
  6. eerygarden
    Feb 13, 2017
    31
    So the amount of DASH awarded in the block reward must be fixed for each block then until the end of the year where it decreases by 7.1% right? In which case why does moobot in the slack say an approximate earning of 8.79 DASH a month?
  7. crowning
    May 29, 2014
    1,428
    2,005
    The number of Masternodes changes all the time, the more/less Masternodes, the longer/shorter you need to wait for your next payment.
    And because no one knows how much Masternodes will be online all those numbers are just estimations based on the _current_ number of Masternodes.
    • Like Like x 2
