How much can ordinary pc mine?
Discussion in 'Mining' started by Alexywolk, Aug 24, 2015.
  1. Alexywolk
    Alexywolk New Member
    Jul 28, 2015
    How much of dash can ordinary pc mine in 8h?
  2. Sub-Ether
    Sub-Ether Well-known Member
    Mar 31, 2014
    1,516
    1,254
    You don't say what hardware you're using.
    Rough guide, in 24 hrs with a good graphics card hashing at 6 meg,you might get 0.2 Dash per day(.03 dash per mega hash per day)
    With a cpu only running 8 threads giving 0.3 megahash, you will get around .01 Dash per day (0.0033 dash in 8 hrs)
    check coinwarz for various estimates.
  3. Dash4Ever
    Dash4Ever Active Member
    Sep 24, 2015
    106
    105
    93
    Dash Address:
    XybaxnhtFBih2g4M2F71rWKBt5USzo8R
    I'm thinking about getting a new AMD GPU for mining some DASH, do you have any recommendation ? just one PCI-E x16
  4. Sub-Ether
    Mar 31, 2014
    1,516
    1,254
    NVidia meant to getting better on power consumption and more optimized but I only use AMD, my best card is a R9 290 tri X, and I get around 8.5 megahash speed with that.
    Edit: I like how I can undervolt it, be careful to get a card that is unlocked otherwise you can be running high temps and wasting power for nothing!
    My XFX R9 280X is voltage locked, and its really annoying, I even flashed the ROM but it will not unlock, I think the regulator is missing off the board, so buy better makes and check em.
  5. Dash4Ever
    Sep 24, 2015
    106
    105
    93
    Dash Address:
    Same here, only use AMD and will allways do :) thanks for the advice ! Nice rate, any overclock, temp ?
  6. Sub-Ether
    Mar 31, 2014
    1,516
    1,254
    All settings maxed out,that was cooking at 90C actually-I did get it upto 9.4 megahash, was trying to get past the big 10, but the computer crashes, lol.
    hang on ...
  7. Sub-Ether
    Mar 31, 2014
    1,516
    1,254
    Just for you ;)
  8. Sub-Ether
    Mar 31, 2014
    1,516
    1,254
    Undervolted much cooler and only a little slower on default clock speed,
  9. Sub-Ether
    Mar 31, 2014
    1,516
    1,254
    I crashed after that demo above, btw.
    Good tip (which I don't follow) is gradually change your clock speeds/voltages rather than steam in there, whacking everything upto 11 in one go :rolleyes:
  10. Wolf0
    Wolf0 Member
    Oct 7, 2014
    71
    56
    I've hit 10.25, just barely, with 290X.
    • Like Like x 1
  11. Sub-Ether
    Mar 31, 2014
    1,516
    1,254
    You are always 1 step ahead, Wolf,
    btw hope you got your little tip alright, I was mentioning you to someone (again) and I felt it courteous as they were using your work.
  12. Wolf0
    Wolf0 Member
    Oct 7, 2014
    71
    56
    Thanks; and don't worry, it was with 1200/1700 clocks.
