How long does the mixing take for coins worth 250 eur?
Kong
55
15
Hi,
how long does the mixing take for coins worth 250 eur? Want to make a purchase at abraxas....
Greets
Reactions: studioz
TanteStefana
2,871
1,863
I don't know for certain, but I'd say a few hours. If you do it before you go to bed, they should be done by morning, I'm pretty sure. But it's been a while for me. I'm running a liquidity provider, which means I'm constantly mixing with others, and I use up about 150 addresses a day depending on how many people are mixing on a particular day. I'm not the only one, I know there are quite a few of us, at least 3 if not 20 or more. So you should always get a mix pretty fast.
Don't set liquidityprovider= anything in your configure file because then you won't mix unless someone else is requesting. That way, liquidity providers don't bloat the block chain by constantly mixing with each other :p
Reactions: studioz
rightaboutnow
27
16
been trying to mix a small amount of coins last several days only to get stuck at 13% left running for 48 hours now, is it time to press the reset button?
Reactions: studioz
tungfa
8,900
6,740
restart wallet
I am mixing all my wallets on a constant
(providing liquidity for others and keeping mine in the mix)
sometimes mix get 50-100 pretty fast
and sometimes it takes forever
is mine are always up and running I restart wallet once or twice a day (for the spirit)
Reactions: studioz
fernando
Powered by Dash
1,527
2,058
Absolutely. I have mixed in the last couple of days around 200 DASH and I only opened the wallet at certain times. It is not fast, but it should not be THAT slow!
Reactions: studioz
