You can use coincontrol (choose from top menu options/wallet/coin control feature) to unlock the collateral of 1000 and spend them or before starting your wallet in file masternode.conf put the "#" in front of the line which is your masternode config.
I found on testnet if you have masternode.conf it will auto lock masnternode funds you may need to turn off masternode setting to unlock the 1000 collateral hope that helps if it was not simply coin control option.
