Meedigital
Hello I need a step-by-step tips to make my wallet work again.
When I first started qt it asked to choose a folder where the wallet's files will be. I set a easier location "C:/xcoin" not that Roaming in windows.
I created and was using my wallet in windows but I needed to format my computer. I copy pasted to a new partition before formating.
Ok. my files are saved. But how to recover my wallet if the installation program "Ask to choose a NEW folder again?" I don't want a new wallet. I want to use the "backup" i did in that partition.
I Tried this until now:
1. Created a C:/xcoin again with my "backup" inside and run the qt. (No dunuts). It overwrited my wallet.
2ºnd try: Deleted the folder that was overwrited and just runt Qt creating a folder with same name and Then deleted the files the program created and copied my backup in the folder that program created. (no donuts was created a new darkcoin address)
3º Unistalled the program needing for help.
