Hashing Speeds
A
admin
Guest
Post your hashing speeds.
CPU MINING
Processor: AMD Phenon II X6 1050T Stock clocks.
Mining Software: ig0ttik3d cpu-miner v1.2c
Hash Speed: 276.40 khash/s
GPU MINING
Graphics card
: ATI Radeon HD 5700 *1
Mining Software:
Hash Speed:
darkness
46
10
GPU MINING
Graphics card
: ATI Radeon 7950 (1100)
Mining Software: sgminer
Hash Speed: ~1.2 Mhash/s
I've only just started though so I will update once I've messed about with the settings a bit more.
SenseiNoobie
6
GPU MINING
Graphics card: X3 r9 280x Toxic
Mining Software: PHM-Sgminer
Hash Speed: 2.3 Mhash/s per GPU
A newbie to mining...
seanp25
CPU MINING
Processor: Intel Core i5-2450M 2.5GHz
Mining Software: cpu-miner 2.3.2
Hash Speed: 51 khash/s
CPU MINING
Hash Speed: 102 khash/s
Is there a working GPU miner out there for Nvidia cards?
Rux
69
32
R9 280x Gigabyte windforce rev.2 @ 2.1Mh/s - Very loud card, around 73C when mining DRK
R9 280x Asus DCUII @ 2.1Mh/s - Very quiet and cold card, around 65C while mining drk
Sensei, what settings you used for 2.3 Mh/s ? :) or what miner version, please send link....
Lzeppelin
57
I get ~ 1.3 MH/s on a 7870 with -I 20 -g 2 -w 256 --gpu-engine 1150 --shaders 1792 --gpu-powertune 20 --gpu-fan 8-85
edit: using SPH-SGMINER
Hubert Farnsworth
CPU MINING
Processor
: Intel i5 3570k
Hash Speed: ~115 KH/s
GPU MINING
Graphics card
: MSI R9 270
Hash Speed: ~ 1.3 MH/s
Not sure if mining with the CPU is really worth the extra power draw, but might as well put it to use.
just_mike
218
20
78
Los Angeles
CPU MINING
Processor: AMD FX-8320
Mining Software: elmad cpu-miner v1.3 avx-aes
Hash Speed: 380 khash/s (using 6 cores)
GPU MINING
Graphics card
: ATI Radeon HD 5830
Mining Software: SPH-SGMINER v4.1.0
Hash Speed:
908 khash/s
Graphics card: ATI Radeon HD 6950
Hash Speed:
1.32 mhash/s
fra55
143
14
68
CPU MINING
Processor
: Intel i5 2400 @ 3.1 ghz
Mining Software: elmad cpu-miner v1.3 avx-i
Hash Speed: 320 khash/s (using 4 cores)
GPU MINING
Graphics card
: ATI Radeon HD 6850
Hash Speed: 880 khash/s
LazarusLong10
36
CPU Mining:
Processor: AMD Fx-8150 Eight Core Processor @ 3.6 GHz
Mining Software: cpu-miner 1.3
Hash Speed: 350 khash/s
GPU Mining
Graphics Card: Radeon 6770M
Mining Software: sgminer v4.1
mahowi
49
7
Germany
CPU MINING
Processor: AMD FX-6300 @ 3.5 GHz
Mining Software: elmad's darkcoin-cpuminer-1.3-avx-aes
Hash Speed: 300 kH/s (@ 5 cores)
GPU MINING
Graphics card
: AMD Radeon HD 7950 *2
Mining Software: sph's sgminer 4.1.0-96-g983e
Hash Speed: 3.8 MH/s (1.9 MH/s per card)
MrMime
169
36
188
GPU Mining
Graphics:
Gigabyte AMD R9 290 x4
Hash Speed: 9.2 Mh/s (2.3 MH/s / card)
ErrorId
158
41
Canada
CPU Mining
Processor: Intel i5 3570K (stock)
Hashes: ~390KH/s using 4 cores
Software: CPUMiner 1.3 / minerd-corei7-avx file
GPU Mining
GPU: Radeon HD 7870 XT
Hashes: ~1.77MH/s
Software: sgminer 4.1.0
NameUser
10
GPU Mining
GPU: ASUS R9 280X DC2T
Hashes: 2.388Mh/s
WU: 0.033/m
Software: SGMiner 4.1.0
Settings
http://pastebin.com/PdvMCKfY
On another note, does anyone know why I'm unable to make use of avx on my i7 3770k? Others that have the same CPU as mine are able to run 'darkCoin-cpuminer-1.3' with 'minerd-corei7-avx'. I'm ONLY able to run the miner with 'minerd-aes-sse2-sss3', otherwise the miner will start and then just shutdown. The miner window appears for a split second displaying the text "Launching miner...". I'm using W7 64 with 8GB RAM.
n00b_miner
17
fra55
143
14
68
GPU Mining
Hashes: 2.388Mh/s
WU: 0.033/m
Settings
Did you try to put a "pause" argument at the end of the bat file? Maybe an error message will be displayed
FreeOne
44
GPU R9 290x - 2800 kh/s last time I checked it. Haven't played with the config file yet and don't know how stable it is.
rumple
13
CPU MINING
Processor: Intel® Core™ i7 CPU X 990 @ 3.47GHz × 12
Mining Software: darkcoin-cpuminer-1.2c (though NEWS says 2.3.2-x) (Ubuntu 13.10)
Hash Speed: 69 khash/s/thread
I usually run --threads=6 if I'm going to be at the computer and --threads=10 when I'm away.
22naru
GPU MINING
Graphics card
: ATI Radeon R7950 TF3 * 3
Mining Software: sgminer 4.1
Hash Speed: 5.45 Mh
NameUser
10
Thanks for the tip. It would just display the location of the miner.
I was informed that AVX wouldn't work unless Service Pack 1 was installed, so I upgraded to SP1 and AVX is now supported!
fra55
143
14
68
So it's working now? Great news!
elproducto
GPU MINING
Graphics card: ATI Radeon HD 7850
2 x XFX 7850
1 x Sapphire
Hash Speed:
2 XFX 1.858 Mh/s
1 Sapphire 1.027 Mh/s
Total ~ 2.8 Mh/s
Nmilanov
9
Sofia, Bulgaria
dvtests.com
GPU MINING
Graphics card
: MSI R9 270X HAWK 2G (1245 MHz core, 1500 MHz memory, no voltage increased) fan 50% with temps of 45-48 Celsius, cool room
Hash Speed: 1.48 Mh/s
zuperdoge
12
GPU MINING
Graphics card
: Gigabyte R9 280x
Hash Speed:
Settings: (still tweaking for performance)
"auto-fan": true,
    "gpu-fan": "40-100",
    "temp-cutoff": "90",
    "temp-overheat": "85",
    "temp-target": "75",
    "xintensity": "100",
    "thread-concurrency": "8193",
    "worksize" : "256",
    "lookup-gap" : "1",
    "expiry" : "1",
    "gpu-threads" : "1",
    "vectors" : "1",
    "shaders" : "2048",
    "gpu-dyninterval" : "7",
    "api-port": "4028",
    "api-listen": true,
    "api-allow": "W:127.0.0.1",
    "failover-only" : true,
    "no-pool-disable": true,
    "no-submit-stale" : true,
    "queue": "0",
    "scan-time" : "1",
    "kernel" : "darkcoin",
    "kernel-path": "/usr/local/bin"
Nmilanov
9
Sofia, Bulgaria
dvtests.com
GPU MINING
Graphics card
: Gigabyte R9 280x
Hash Speed:
"auto-fan": true,
    "worksize" : "256",
    "lookup-gap" : "1",
    "expiry" : "1",
    "vectors" : "1",
    "shaders" : "2048",
    "api-port": "4028",
    "api-listen": true,
    "queue": "0",
    "scan-time" : "1",
Nice hash speeds! I'm currently thinking of adding a 280x under my 270x, is it possible to run into some isses? gpu-threads:2, on my 270x at the moment. Couldn't find any usable info about pairing 270x and 280x.
yidakee
1,812
1,168
GPU Mining
Graphics card:
Sapphire 280-X Vapor-X
Hash Speed:
This is obviously pointing to p2p. Can get 11.2MH/s 0% pointing to MPOS but with entirely different settings.
Settings:
-k darkcoin -o stratum+tcp://drk.altmine.net:7903 -u Xt3Adarkrocks!1LbZKnCLDKMG3nukuziH3aaha.!. -p x --auto-fan --gpu-fan 40-85 --temp-cutoff 92 --temp-overheat 88 --temp-target 64 -I 18 -g 1 -w 128 --lookup-gap 2 --thread-concurrency 8192 --gpu-powertune 20 --gpu-engine 1100 --gpu-memclock 1500
