Guide for running multiple wallets instances in same OS
TurK-FX
With this guide, you can run multiple wallet in same OS using the same block chain.
Let me know what you guys think...
The sound is so awful, I can't hear what you're saying except the "clicks".... I think this video would be a great help but you need to redo it.
Oh there is sound? I recorded with sound, but then, I could not hear anything. I thought my mic is not working. SO I added the conversation bubbles to explain.
Cool!
Use -listen=0 and you will be able to run multiple wallets at the same time! (Or use different ports, -port=9990 -rpcport=9980, etc...)
Your -wallet=mn3wallet.dat flag seems not to work as it was generating a new wallet (see the loading indicator in 4:32)...
Cool!
Ok I will look into it. Add -listen=0 command and test it. And figure mn3 wallet why not working. Thanks for the pointers. Hopefully I will figure out the problem with my mic and will be full sound this time.
It looks like I figured everything except running wallets simultaneously. -port=9990 -rpcport=9980 or -listen=0 not working
