delete
Discussion in 'Masternode Guides' started by bituzer, Jun 28, 2014.
  1. bituzer
    bituzer Member
    Apr 23, 2014
    19
    26
    78
    #1 bituzer, Jun 28, 2014
    • Like Like x 2
  2. vertoe
    vertoe Three of Nine
    Mar 28, 2014
    2,574
    1,656
    This indeed updates the darkcoin daemon, but it does not restart the masternode.
  3. yamada
    yamada New Member
    May 26, 2014
    31
    21
  4. DrkMiner
    DrkMiner Member
    Jun 7, 2014
    204
    63
    I used the code above and improved it a bit...
    #!/bin/sh
    echo "########### This script will update the Master Node"
    sleep 5
    VERSION=64
    URL=$1
    FILE=${URL##*/}
    DIR=${FILE%.tar.gz}
    IP=$(hostname -I)
    wget $URL
    tar xzvf $FILE
    echo "########### Stopping the Master Node"
    ./darkcoind stop
    sleep 7
    rm darkcoind
    cp $DIR/bin/$VERSION/darkcoind .
    chmod 755 darkcoind
    rm $FILE
    rm -rf $DIR
    rm .darkcoin/peers.dat
    echo "########### Restarting the updated Master Node"
    sleep 5
    ./darkcoind
    sleep 15
    ./darkcoind getinfo
    sleep 5
    echo "########### Master Node status - Active: 1, Inctive: 0"
    ./darkcoind masternode list | grep $IP
    save as update.sh and chomd 755
    run from SSH:
    ./update.sh https://raw.githubusercontent.com/d...es/master/rc/darkcoin-0.10.12.32-linux.tar.gz
    link to the new/update tar.gz file will be available on Darkcoin.io
    If HOT wallet is used on the MN a new wallet is needed to upgrade to the new RC5.
    #4 DrkMiner, Sep 21, 2014
    • Like Like x 5
  5. DrkMiner
    DrkMiner Member
    Jun 7, 2014
    204
    63
    sleep 5
    ./darkcoind
    sleep 30
    ./darkcoind getinfo
    sleep 20
    In some cases you will need to increase the "sleep" time to give darkcoind more time to fully load.
  6. tungfa
    tungfa Administrator
    Apr 9, 2014
    8,945
    6,731
    that is great,
    can you please post a final version in the OP ?!
    tx
  7. camosoul
    camosoul Grizzled Member
    Sep 19, 2014
    2,240
    1,124
    Oh, contrariwise; you most absolutely must without exception, always. The new daemon will not know it is an MN in spite of there being such in the config. Without a "masternode start" it will just sit there, never ping the network, become inactive, then drop off the list entirely, and when using start-many, that's a pain to deal with... Ask me how I know this...
    Even when you do a "masternode start" it often does not stick and has to be re-issued over and over and over again until you see "last seen" reset on it's own, without issuing the "masternode start" command. Just keep doing "masternode start" until the daemon starts pinging, or you're going to have one hell of a mess and probably be forced to destroy all your VMs, move all your DRK to new addresses, and start over completely.
    #7 camosoul, Nov 19, 2014
  8. moocowmoo
    moocowmoo Bovine Bit-flipper
    Jun 15, 2014
    483
    603
    263
    Dash Address:
    my "hat in the ring" version. Note: hardcoded for 64bit linux... YMWV
    #!/bin/bash
    GETURL=https://raw.githubusercontent.com/darkcoinproject/darkcoin-binaries/master/
    if [ -z $1 ] ; then
        echo "usage: $0 darkcoinversion"
        echo "eg: $0 0.10.16.16"
        exit
    fi
    version=$1
    GETFILE=darkcoin-${version}-linux.tar.gz
    GETURL=${GETURL}${GETFILE}
    if [ ! -e $GETFILE ] ; then
        wget $GETURL
    fi
        echo "error downloading file"
        echo "tried to get ${GETURL}"
        exit
    fi
    #unpack it
    tar zxvf $GETFILE
    #copy it
    cp darkcoin-${version}-linux/bin/64/darkcoind ~/.darkcoin/darkcoind-${version}
    #remove unneeded
    rm -rf darkcoin-${version}-linux
    #work it
    cd ~/.darkcoin
    #stop it
    darkcoind stop
    #wait it
    sleep 5
    #clean it
    rm -f debug.log peers.dat
    #link it
    rm darkcoind && ln -s darkcoind-${version} darkcoind
    #start it
    ./darkcoind &
    Brittle, could use more error handling... but as long as the directory/filename structures remain consistent... should work until it doesn't.
  9. UdjinM6
    UdjinM6 Official Dash Dev
    Dash Core Team Moderator
    3,637
    3,536
    Ok, here is mine :)
    #!/bin/bash
    date
    if [ $1 ]; then
    DARK=darkcoin-$1-linux
    wget https://github.com/darkcoinproject/darkcoin-binaries/raw/master/$DARK.tar.gz
    tar -xvf $DARK.tar.gz
    chmod u+x $DARK/bin/64/darkcoind
    else
    cd ~/darkcoin/
    git pull
    cd src/
    make -f makefile.unix USE_UPNP=-
    fi
    darkcoind stop
    sleep 5
    mv /usr/bin/darkcoind /usr/bin/darkcoind.old
    if [ $1 ]; then
    mv $DARK/bin/64/darkcoind /usr/bin/
    rm -r $DARK*
    else
    cp darkcoind /usr/bin/
    fi
    darkcoind
    Usage is
    ./mn_update.sh 0.10.16.16
    to get binaries of exact version or
    ./mn_update.sh
    to get latest github commit and compile by yourself (you have to have all needed dev libs installed first of course)
    • Like Like x 2
  10. oblox
    oblox Well-known Member
    Aug 6, 2014
    1,032
    537
    You only need to issue a masternode start from local assuming the remote masternode isn't offline for too long to drop off the list on protocol bumps. If the protocol stays the same, using anyone of these update scripts to stop the remote masternode for about 30-60 seconds while updating won't require you to load the local wallet up.
  11. tungfa
    Apr 9, 2014
    8,945
    6,731
    Can you please start working on "rebranding" the guide ?!
    that would be great and super appreciated
    Tx
  12. tungfa
    Apr 9, 2014
    8,945
    6,731
    whow are you fast !!
    I did not see that , sorry
    well done and tx
  13. BolehVPN
    BolehVPN Active Member
    Nov 24, 2014
    195
    305
    123
    Hi :D I have updated the script but it requires 'bash'
    it's a bit of a hacky way so I'm open to how to improve it (I'm not a programmer)
    For upgrading to v12.
    #!/bin/bash
    sleep 5
    URL=$1
    FILE=${URL##*/}
    DIR=${FILE:0:11}
    cd ~/.dash
    wget $URL
    tar xzvf $FILE
    ./dashd stop
    sleep 5
    rm dashd
    cp $DIR/bin/dashd .
    cp $DIR/bin/dash-cli .
    chmod 755 dashd
    rm $FILE
    rm -rf $DIR
    rm peers.dat debug.log db.log
    sleep 2
    ./dashd -reindex
    Once on v12 and future updates (provided no more changes in directory structure)
    #!/bin/bash
    sleep 5
    URL=$1
    FILE=${URL##*/}
    DIR=${FILE:0:11}
    cd ~/.dash
    wget $URL
    tar xzvf $FILE
    ./dash-cli stop
    sleep 5
    rm dashd
    cp $DIR/bin/dashd .
    chmod 755 dashd
    rm $FILE
    rm -rf $DIR
    sleep 2
    ./dashd
    • Like Like x 2
  14. DarkWater
    DarkWater Well-known Member
    May 14, 2014
    111
    98
    193
    BolehVPN THANK YOU! This made my life alot easier! Now I can update all my NM! Meant to update sooner but Ill have to redo all my scripts to get this ball rolling.
    • Like Like x 1
  15. moocowmoo
    Jun 15, 2014
    483
    603
    263
    Dash Address:
    For all you folks running version 12 on linux:
    https://github.com/moocowmoo/dashman
    (Read the README, this script places the executables in ~/.dash -- I'll add destination folders eventually.)
    [​IMG]
    Let me know if you run into any trouble. I'll push bugfixes as we find them. ;)
    (32bit install untested, but should work, lmk)
    #15 moocowmoo, Aug 26, 2015
  16. Solaso
    Solaso Member
    Aug 20, 2015
    134
    20
    68
    Please tell me about work on Ubuntu?
  17. Solaso
    Solaso Member
    Aug 20, 2015
    134
    20
    68
    Thank you. Please tell me, can I add this to autoload and add to crontab?
  18. moocowmoo
    Jun 15, 2014
    483
    603
    263
    Dash Address:
    It will work fine on ubuntu.
    It is meant to be run manually.
    It expects your dashd and dash-cli be in your ~/.dash folder.
    (I'm working on making that part smarter for alternate layouts.)
    • Like Like x 1
  19. moocowmoo
    Jun 15, 2014
    483
    603
    263
    Dash Address:
    Update script updated (through the power of scripting!)
    UPDATES
    • Will now attempt to locate where you've installed your dashd/dash-cli
    • Shows pretty output of what its done (and where it's done it!)
    BUGS
    • Probably
    • Still only works on Linuxes
    • Still can't deliver beers on demand
    • Others you haven't told me about yet
    [​IMG]
    get it at https://github.com/moocowmoo/dashman
    And let me know if you run into trouble!
    • Like Like x 5
  20. DarkWater
    May 14, 2014
    111
    98
    193
    This update script rocks! Just switched over to this and it went smooth as butter. Now if I can figure out why I can't successfully resync to the network. Block height matches but doesn't show up on the list.
  21. Solaso
    Solaso Member
    Aug 20, 2015
    134
    20
    68
    Thank you, in manual I see error
    for it to work you need a symbolic link from /usr/bin/dashd to ~/.dash/dashd: "sudo ln -s ~/.dash/dashd /usr/bin/" and same for dash-cli "sudo ln -s ~/.dash/dashd /usr/bin/"
    Double sudo ln -s ~/.dash/dashd /usr/bin/ may be one sudo ln -s ~/.dash/dash-cli /usr/bin/"
  22. Solaso
    Solaso Member
    Aug 20, 2015
    134
    20
    68
    [email protected]:/home/user1/dashman# ./update_dashd.sh
    readlink: missing operand
    Try 'readlink --help' for more information.
    dashd not found in -- Exiting.
    On my server dashd upper folder dash. Where I wrong? Thank you
  23. moocowmoo
    Jun 15, 2014
    483
    603
    263
    Dash Address:
    update_dashd.sh looks in three places for dash-cli and dashd:
    • the current directory
    • ~/.dash
    • all directories in your PATH variable
    In your case, do:
    cd ~/dash
    ../dashman/update_dashd.sh
    and it should work. Let me know if you have more trouble.
  24. Solaso
    Solaso Member
    Aug 20, 2015
    134
    20
    68
    Yes) I started this
    [email protected]:/$ cd ~/
    [email protected]:~$ dashman/update_dashd.sh
    But I see finished install
    Installed in /home/user1
    -rw-rw-r-- 1 19892539 Sep 4 18:10 dash-0.12.0.53-linux64.tar.gz
    -rw-rw-r-- 1 186 Sep 4 18:10 dash-0.12.0.53-linux64.tar.gz.DIGESTS.txt
    lrwxrwxrwx 1 18 Sep 5 19:59 dash-cli -> dash-cli-0.12.0.53
    -rwxr-xr-x 1 2548784 Jan 10 2014 dash-cli-0.12.0.53
    lrwxrwxrwx 1 15 Sep 5 19:59 dashd -> dashd-0.12.0.53
    -rwxr-xr-x 1 9423200 Jan 10 2014 dashd-0.12.0.53
    lrwxrwxrwx 1 17 Sep 5 19:59 dash-qt -> dash-qt-0.12.0.53
    -rwxr-xr-x 1 13339504 Jan 10 2014 dash-qt-0.12.0.53
    Its right? Or now I should to rename dashd-0.12.0.53 to dashd?
  25. moocowmoo
    Jun 15, 2014
    483
    603
    263
    Dash Address:
    If that's where you wanted it installed, sure.
    No need to rename, it's symlinked. ./dashd and ./dash-cli will just work.
    • Like Like x 1
  26. Solaso
    Solaso Member
    Aug 20, 2015
    134
    20
    68
    Thank you! Can I start this in cron? For example once in week?
    #26 Solaso, Sep 5, 2015
  27. moocowmoo
    Jun 15, 2014
    483
    603
    263
    Dash Address:
    not yet. Future versions will support unattended installs.
    • Like Like x 1
  28. Solaso
    Solaso Member
    Aug 20, 2015
    134
    20
    68
    Good news! Thank you!
  29. moocowmoo
    Jun 15, 2014
    483
    603
    263
    Dash Address:
    Version 0.1 of dashman released upon the world! run away, run away!
    (commands have changed, so re-read the README!)
    but, seriously, lmk if you run into borks. :)
    install (fresh)
    [​IMG]
    update (fresher)
    [​IMG]
    reinstall (refresh it!) (by request)
    [​IMG]
    • Like Like x 2
  30. moocowmoo
    Jun 15, 2014
    483
    603
    263
    Dash Address:
    shameless bump.
    now with statusy goodness!
    [​IMG]
    • Like Like x 3
