Dash Wallet
Hi, is it possible dash create a wallet that can be stored on dash.org? That way I don't have to worry about backups or if my computer goes to hell in a hand basket all will be ok?
In the meantime is there a way for me to make my Dash Core Wallet on my pc impossible to access unless I use a password to go into my account? I don't want anyone that uses my PC to be able to look at my Dash balance. I know encryption is used to not be able to send Dash without a password but what I am speaking of is different than that.
"dash create a wallet that can be stored on dash.org"
that is the idea with
https://www.dash.org/evolution/
but for now this is not available from Dash direct
impossible to see and use
DashCore - take the wallet.dat file off your Mac/PC and there will be no more coins to see when opening wallet
called : cold storage
https://dashpay.atlassian.net/wiki/display/DOC/MAC:+Secure+Backup+for+Wallet.dat
for easy light wallet - password only
Exodus or Jaxx
https://dashpay.atlassian.net/wiki/pages/viewpage.action?pageId=48693365
Exodus or Jaxx
Thanks tungfa, you are very helpful. Sending you a donation in a minute to: XstNX6pF9MKNRwwuBYkZhiHpQwbp5yszKd
