Dash p2pool setup help pls
Discussion in 'Questions and Help' started by daleaus, Oct 10, 2015.
  1. daleaus
    daleaus New Member
    Sep 9, 2015
    20
    9
    Hi all,
    I'm working on getting my p2pool setup on the latest ubuntu and I'm having some trouble. I'm using the version from https://github.com/dashpay/p2pool-dash and when i run "python setup.py install" i get ImportError: No module named py2exe.
    Any ideas as to why ?
    Cheers
  2. thelazier
    thelazier Active Member
    Jan 5, 2015
    240
    184
    Dash Address:
    daleaus
    May I know what is the version of your latest ubuntu?
    #2 thelazier, Oct 10, 2015
  3. daleaus
    daleaus New Member
    Sep 9, 2015
    20
    9
    Of course, I'm using Ubuntu 14.04 LTS, Thanks :)
    • Like Like x 1
  4. daleaus
    daleaus New Member
    Sep 9, 2015
    20
    9
    I figure "ImportError: No module named py2exe" has to be the problem with my setup because it's the only error i get when i follow the guide in the github original post, otherwise i can start run_p2pool.py and i see it start with a few errors one of them being no module named x11_hash, i can browse to the p2pool statistics page and i can see it connected to my wallet, I can connect my miner to it but my miner gets [2015-10-10 13:06:03] stratum_recv_line failed.
    I'd love to get this setup, any help is much appreciated
    • Like Like x 1
  5. thelazier
    Jan 5, 2015
    240
    184
    Dash Address:
    May I know if you follow this instruction from README.md file not working?
    Install Python modules:
    Download the required submodules:
    git submodule init
    git submodule update
    x11_hash:
    cd x11-hash
    For stratum_recv_line failed, try running miner for a while, p2pool should connect with other peers and sync the shares during start up which may cause this error for a while...
    • Like Like x 1
  6. daleaus
    daleaus New Member
    Sep 9, 2015
    20
    9
    Thanks for the reply thelazier! When i use "git submodule init" i get "fatal: Not a git repository (or any of the parent directories): .git
  7. thelazier
    Jan 5, 2015
    240
    184
    Dash Address:
  8. daleaus
    daleaus New Member
    Sep 9, 2015
    20
    9
    Got it working now thanks for all your help i have a couple more questions for you if you don't mind.
    I noticed the miner is 1 block ahead of the Dash Block Explorer? is it normal?
    I'm getting spammed with,
    2015-10-11 08:06:57.011039 Local: 24530kH/s in last 10.0 minutes Local dead on arrival: ~1.0% (0-3%) Expected time to share: 20.0 minutes
    2015-10-11 08:06:57.011084 Shares: 0 (0 orphan, 0 dead) Stale rate: ??? Efficiency: ??? Current payout: (0.0000)=0.0000 DASH
    My miner is submitting shares so I'm not sure why the pool isn't reporting them?
    Also since i now have p2pool-dash as a git repository how do i copy a new web front end into web-static when i don't have permission?
    Thanks again mate
    #8 daleaus, Oct 11, 2015
  9. thelazier
    Jan 5, 2015
    240
    184
    Dash Address:
    daleaus
    The miner is trying to work on the new block which is 1 block ahead of Dash Block Explorer, this is normal.
    Got "Yays" on Miner is not always got shares count on p2pool, this is normal.
    The p2pool-dash folder have same file's permission as user who run "git clone" , so you can always change anything as your wishes.
    Congratulation and Enjoy Mining :)
    BTW, I understand that this question should be moved to https://dashtalk.org/forums/questions-and-help.70/ ,
    coingun Propulsion fernando , please kindly help.
    • Like Like x 2
  10. daleaus
    daleaus New Member
    Sep 9, 2015
    20
    9
    Thanks again Lazier, It's all working pretty well.
    so are there currently 2 different P2Pool's on the dash network? after mining on mine for a couple of days I've noticed that it shows up on the chain explorer as P2pool-DASH whenever it finds a block but there looks like there is also P2pool which has a much higher find percentage.
    Do you by chance know how to connect with P2pool ? i can see the website points to a dead link http://drk.poolhash.org
  11. thelazier
    Jan 5, 2015
    240
    184
    Dash Address:
    The information is outdated, I hope they will correct it soon.
    BTW, these blocks are from another pool (dash.poolto.be) as you may see at https://dashninja.pl/blocks.html
  12. frederik
    frederik New Member
    Oct 20, 2015
    P2Pool.org says:
    I am also mining with ccminer on Ubuntu 15.04 on P2Pool.
    While mining, ccminer spits out a diff of something between (diff 0.003) and (diff 0.100).
    [use --show-diff in the commandline]
    curl http://127.0.0.1:7903/difficulty tells me that the actual minimum difficulty is 0.28277951094484216
    Would it matter increasing the difficulty in the commandline of ccminer?
    --username username-or-address/+0.3 to increase diff by 0.3
  13. thelazier
    Jan 5, 2015
    240
    184
    Dash Address:
    The difficulty adjustment is useful when you have too fast solving the hash (, so many yays in a second) based on diff assigned by p2pool node.Anyway, you may try adjust as much as you like. I'm not sure whether this will directly help getting more accurate yays/shares rate.
    Enjoy mining ;)
