Dash Masternode setup Guide
Discussion in 'Masternode Guides' started by buster, Jun 14, 2015.
  1. buster
    buster Guest
    When version 12 is released I will be making a DASH masternode Setup Video Guide: Right now I would like any suggestions for the video so that I can prepare:
    • Like Like x 5
  2. bluebit
    bluebit Active Member
    Jun 4, 2015
    191
    194
    Suggestions:
    - Mac Tutorial
    - How to setup multiple masternodes from 1 wallet.
    - Update Scrypt
    - Vultr or another VPS
    - How to move the masternode to another country in Vultr, i think this is possible?
    - What resources you use to check masternodes are doing ok, do you use an android app or websites?
    - How to setup "Max connections", if bandwidth is getting too high, or what is a good unlimited bandwidth cheap reliable VPS
    - Explain how snapshots in Vultr work for if something goes wrong.
    • Like Like x 1
  3. splawik21
    splawik21 Grizzled Member
    Dash Core Team Foundation Member Dash Support Group Moderator
    Apr 8, 2014
    1,919
    1,278
    I would NOT suggest to use vultr, as there is already 18.35% of all masternodes there.
    What would be much better is how to use http://lowendbox.com to choose a good server to setup on.
    • Like Like x 1
  4. moli
    moli Grizzled Member
    Aug 5, 2014
    3,262
    1,837
    How about guides to set up a MN on all major VPSs? :)
  5. Sub-Ether
    Sub-Ether Well-known Member
    Mar 31, 2014
    1,516
    1,254
    If you can, as well, do a hot/cold wallet with simple config as there is nothing simpler, this is the one that got me started, its a good learning curve before the real local/remote setup.
  6. moli
    Aug 5, 2014
    3,262
    1,837
    Can you make a text guide for the hot/cold wallet?
  7. Sub-Ether
    Mar 31, 2014
    1,516
    1,254
    If you want, but it will have to be only in windows ..
  8. moli
    Aug 5, 2014
    3,262
    1,837
    That's the best OS!
    Jk. But yeah, sure. It will be a popular guide for n00bs like me... :cool:
    Thanks! :)
    • Like Like x 1
