dash address validation
Dashmaximalist
1,008
247
37
maptags.in
i am facing several issues with dash address validation on our website getfreedash.com
the following address entered by users XuGQGK8qwSKWgnEp73sjUK1FHp4WMK7syj and its failing the check sum any reason why ?/
thanks
thephez
Jan 23, 2016
120
59
78
thanks
To put it simply, because it is not a valid address. If you run "validateaddress XuGQGK8qwSKWgnEp73sjUK1FHp4WMK7syj" via dash-cli (or the Dash Core console) to check the address, it returns invalid. You can also see that if you search for the address here - https://explorer.dash.org/address/XuGQGK8qwSKWgnEp73sjUK1FHp4WMK7syj.
Perhaps the user manually typed the address in and got it incorrect?
Dashmaximalist
1,008
247
37
maptags.in
yes correct, i need a tool to run check dash address on my site getfreedash.com
Appreciate your help !
