DarkSend 990.99 balance
Discussion in 'PrivateSend Questions and Help' started by freshdopamine, Jul 2, 2016.
  1. freshdopamine
    freshdopamine New Member
    May 28, 2016
    38
    6
    I have more than 1000 DASH and the mixing says its complete 100% how do I go about to having 1000 Darksend balance?
  2. freshdopamine
    May 28, 2016
    38
    6
    Bump anyone have a clue?
  3. Solarminer
    Solarminer Well-known Member
    Apr 4, 2015
    762
    921
    163
    The answer is you can't have 1000 Dash as a mixed balance. Darksend/PrivateSend stops at 999.99/999.999 coins. If you are intending to hide history for a masternode input, I would suggest creating a 2nd wallet to send mixed funds to. Then send those funds to your masternode. I have had trouble sending a mixed input with 1000 mixed coins because the number of transactions is too high.
    Wallet 1 = 1000+ dash. Mix
    PrivateSend 500.999 dash to Wallet 2 (using .999 will minimize the round up fee for PrivateSend)
    Remix Wallet 1
    PrivateSend 500.999 dash to wallet 2
    Standard Send 1000 dash.
    • Like Like x 1
  4. bertlebbert
    bertlebbert Active Member
    Jul 17, 2014
    669
    289
    Great explanation... I just learned something, thx @Solarminer
  5. UdjinM6
    UdjinM6 Official Dash Dev
    Dash Core Team Moderator
    3,631
    3,532
    This is incorrect. Darksend/PrivateSend has a limit of 999.99 DASH for a single mixing session only.
    static const int64_t DARKSEND_POOL_MAX = (999.99*COIN);
    The "limit" how much you can mix in total is 999999 DASH using cmd-line params
    if(nAnonymizeDarkcoinAmount > 999999) nAnonymizeDarkcoinAmount = 999999;
    and 2000 DASH max using GUI settings.
    So in general there is no need to create another wallet to mix more.
    @freshdopamine check settings and make sure "Amount of Dash to keep anonymized" is above 1000 to mix more.
  6. Solarminer
    Apr 4, 2015
    762
    921
    163
    I might be able to read code, but udjin understands the code. Thanks for correcting.
    I had an issue sending mixed funds with a version .56 or before wallet on Windows. Transaction would not send, maybe too many inputs. The transaction sent from a Linux wallet without a problem. So there still is a maximum transaction size, or limited number of inputs, you can send. And Linux wallets might handle mixed inputs better.
  7. UdjinM6
    3,631
    3,532
    Yep, there is 100kb per tx limit. I doubt it's Windows vs Linux problem though - the code is the same in that part, it simply compiled for different platforms. Could be that Windows wallet just used way too many smaller denoms and tx size hit the limit which could give "transaction is too big" error or the opposite - had not enough of smallest denoms to combine them into requested amount and since Darksend tx cannot have change that could give "fee is too high" error.
  8. freshdopamine
    May 28, 2016
    38
    6
    Thanks for the info...
Share This Page
