Crowdfunding for Dash Savings, Dash Savings: a easy way for Venezuelans to acquire Dash.
Discussion in 'Pre + Budget Proposal Discussions' started by rjjerez, Feb 2, 2019.
  1. rjjerez
    rjjerez Member
    Apr 4, 2018
    76
    Hello everyone, I'm thankful to the entire community that voted for our latest proposal in Dashboost, especially to the MNOS, entitled:
    Dash Savings: an easy way for Venezuelans to acquire Dash.
    https://www.dashboost.org/proposals/view/128/Dash Savings: a easy way for Venezuelans to acquire Dash.
    We continue to firmly believe that what is needed for Venezuelans to start massively operating with Dash is to facilitate their acquisition, showing how easy it is to buy Dash and then recommend where to spend them.
    Having several liquidity agents in each city of the country, would give the final touch to the adoption in our country, users already have the information, thanks to Dash Venezuela, there's the shops thanks to Dashmerchant and the support, thanks to Dashhelp, maybe the rest of the community didn't precisely understand the goal of our proposal, we can show that we can be self-sustaining and maintain ourselves over time, giving measurable results for each $ spent.
    For all this we dare to place this Crowdfunding for Dashsavings, with the greatest commitment to give all the MNOS the best results and raise the value of our currency.
    Over here we leave the link for the donations:
    XrZFhdhahcSVUXQxLUbH1Qepoq45zTirLs
  2. Damian Walker
    Damian Walker Member
    May 30, 2017
    158
    44
    Hi @rjjerez , please check you DashBoost link, maybe you need to re-upload to other service.
    Regards.
  3. tungfa
    tungfa Administrator
    Apr 9, 2014
    8,964
    6,737
    Hola a todos, estoy agradecido a toda la comunidad que votó por nuestra última propuesta en Dashboost, especialmente a MNOS, titulada:
    Dash Savings: una forma fácil para que los venezolanos adquieran Dash.
    https://www.dashboost.org/proposals...s: a easy way for Venezuelans to acquire Dash.
    Continuamos creyendo firmemente que lo que se necesita para que los venezolanos comiencen a operar masivamente con Dash es facilitar su adquisición, mostrar cuán fácil es comprar Dash y luego recomendar dónde gastarlos.
    Teniendo varios agentes de liquidez en cada ciudad del país, daría el toque final a la adopción en nuestro país, los usuarios ya tienen la información, gracias a Dash Venezuela, están las tiendas gracias a Dashmerchant y el soporte, gracias a Dashhelp, tal vez el El resto de la comunidad no entendió con precisión el objetivo de nuestra propuesta, podemos demostrar que podemos ser autosuficientes y mantenernos con el tiempo, dando resultados mensurables por cada $ gastado.
    Por todo esto, nos atrevemos a colocar este Crowdfunding para Dashsavings, con el mayor compromiso de dar a todos los MNOS los mejores resultados y aumentar el valor de nuestra moneda.
    Por aquí os dejamos el enlace para las donaciones:
    [ADJUNTAR] 9329 [/ ADJUNTAR]
    I posted your spanish here
    do NOT post 2 threads in same section in different languages
    if you wanna reach spanish community , post in the spanish section please
