CoinReform.com is a new cryptocurrency service which allows you to convert one type of cryptocurrency to another (e.g.: Bitcoin to Litecoin).
CoinReform.com advantages:
How to use CoinReform.com website?
5. You need to send cryptocurrency to the deposit address. It will take some time to get required number of confirmations and after that you’ll get a converted cryptocurrency to your receiving address (Litecoin address in this example).After completing these 5 steps you can reuse the deposit address: just send suitable amount to deposit address without visiting a website and you’ll get your coins automatically exchanged at the address you’ve specified in 2).
Adam Saferite, the head of CoinReform.com:
“CoinReform simplifies the process of cryptocurrency conversion for everyone.
CoinReform blurs the difference between blockchains.
Just make one exchange at the website, record your deposit address and convert your cryptocurrency from one type to another without visiting CoinReform.com.
CoinReform saves your time.”
CoinReform.com was founded in 2016. It’s a young and highly demanded service for quick cryptocurrency exchange.
Reform your coins with CoinReform.com!
www.coinreform.com
- There is no need in registration
- All conversions are happening automatically once there is certain amount of confirmations on the blockchain
- Rate is fixed for 10 minutes
- Simple and powerful API
- Deposit address is bound to destination address and can be reused
- We do not require any registration info, so there is no information about client
- We don't share any transactions made through our platform with any 3rd party services
- Service is completely anonymous - you can access website from tor as well
- You need to choose type of source/destination cryptocurrency you’d like to exchange (e.g. Bitcoin to Litecoin)
- Fill your receiving address (e.g. Litecoin address)
- All other fields are optional, but you can use them as well
3.1. Refund address is used in case you send more than a maximum allowed amount for this direction, refunds are automatic if refund address was specified otherwise please contact our support.
3.2. If you would like to get certain amount of cryptocurrency - use optional Amount field.
4. CoinReform.com will give you a deposit address3.2. If you would like to get certain amount of cryptocurrency - use optional Amount field.
www.coinreform.com
