Worked on replicating some of the issues that @Stealth923 had on iOS to see if same issues on Android. His review is linked: https://www.dash.org/forum/threads/co-pay-testing-review-apple-ios.39108/
Will add additional issues as I find them.
Functionality Review:
1) InstantSend is NOT working - when I send a transaction using InstantSend I dont get 6 confirms immediately. It starts at 1.
Confirmed on Android
2) It takes on average 2-5 minutes for a single transaction to be sent through the network, to get a single confirm, cant use that wallet again until its sent. Only when you go into advanced settings and enable "Use unconfirmed funds" can you send funds from the wallet again. How will normal users know how to do this? If not it will take 2-5 min per transaction.
Confirmed on Android. Get "insufficient funds message". UX fix would be to display message along with explanation and a button to go to settings to enable "Use unconfirmed funds"
3) After I have sent a transaction, from a wallet, using InstantSend (which doesnt work) and I try to send a second NORMAL transaction I get random errors saying "InstantSend requires all dash you are sending to be held for about 15-20min"????? The wallet I am sending from has plenty of funds which have > 6 confirms. This has something to do when pasting the wallet address in manually. Seems to work fine when sending to address book contact.
User Experience/User Interface Review:
1) This is a public beta, why is there old branding and new branding mixed throughout the wallet, this is sloppy and shows complete lack of attention to detail. Finish simple things like this or dont release it to public beta!!!!!! Dash Wallet logo on Home screen is also low resolution and wrong size compared to wallet logos below.
100% agree with this.
2) On the main screen, Recent transactions has a red circle and the number of transactions completed. When you click to go into details of recent transactions the red circle on the main screen should gclear and reset the count. Instead the number just keeps going up.
Agree with this, the red circle should serve as a notification of "new transactions".
3) Whats with the science picture for each wallet profile....cant change it, why have it?
I think it stands for "Testnet"
4) From a UI perspective on the Home screen, the Dash wallets should be at the top, not at the bottom where you need to scroll down to see them all when you have 3 or more transactions. Or somehow look to condense the number or padding of recent transactions shown on the main screen. I know you can turn it off in advanced settings as well.
Agreed, wallets should go first.
5. When I go to scan QR code, a grey old Dash logo covers up the first part of the address. Would make it hard to confirm that the address is correct. Image attached.
6. After I scan a QR code then choose "add as contact" I have to scan the QR code again. Instead it should auto-fill that with the address that I wanted to add as contact.
