CCminer X11 mining on NVidia cards
Discussion in 'Mining' started by yibble, May 10, 2014.
  1. yibble
    yibble Member
    Apr 8, 2014
    63
    9
    At least, that's what the project page says: https://github.com/cbuchner1/ccminer
    I currently don't have the space on my headless miner to go a compile a binary, but it appears to be genuine.
  2. Lzeppelin
    Lzeppelin Member
    Feb 27, 2014
    57
    Great news if true, it will boost the number of potential darkcoin miners. With more miners each coin will be harder to get and hopefully receive a boost in price.
  3. yibble
    yibble Member
    Apr 8, 2014
    63
    9
    Absolutely! I've been unable to compile it so far, so I'll have another look tomorrow.
    /home/-/build/ccminer/cpu-miner.c:903: undefined reference to `scanhash_nist5'
    /home/-/build/ccminer/cpu-miner.c:908: undefined reference to `scanhash_x11'
    collect2: ld returned 1 exit status
    make[2]: *** [ccminer] Error 1
    make[2]: Leaving directory `/home/-/build/ccminer'
    make[1]: *** [all-recursive] Error 1
    make[1]: Leaving directory `/home/-/build/ccminer'
    make: *** [all] Error 2
  4. hu398
    hu398 New Member
    May 13, 2014
    12
    I'm getting 1.8mhash on P2Pool with an NVidia GTX 760 (ccMiner v1.0 windows binary). Apparently x11 hasn't been optimized in this release, so future releases of ccMiner might improve the has rate further. Either way it is a huge improvement on CPU only mining and Christian deserves credit for the work he's put in to allow NVidia owners to mine Darkcoin.
    • Like Like x 2
  5. rumple
    rumple New Member
    Apr 3, 2014
    13
    Build issue for me (64-bit 13.10):
    Stack dump:
    0. Running pass 'Live Variable Analysis' on function '@_Z24myriadgroestl_gpu_sha256Pj'
    Segmentation fault (core dumped)
    make[2]: *** [cuda_myriadgroestl.o] Error 139
    cicc crashed with SIGSEGV in llvm::LiveVariables::HandleVirtRegUse()
    reason: writing NULL VMA
    with: nvidia-cuda-toolkit 5.0.35-7ubuntu1
  6. noruka
    noruka New Member
    Apr 2, 2014
    15
    anyone got a 750ti running x11?
  7. lohveh
    lohveh New Member
    May 16, 2014
    No i have 2 660 + 1 660Ti but the 750ti should run @2mhs
    #7 lohveh, May 19, 2014
  8. aminkorea
    aminkorea New Member
    May 23, 2014
    5
    Is there a windows binary for cuda anywhere to be found? I have 7 nVida 750Ti that I would like to start mining with but I am not a linux person.
  9. phryed
    phryed Member
    Mar 9, 2014
    40
    you can use the built version here:
    http://cryptomining-blog.com/tag/ccminer-x11/
  10. aminkorea
    May 23, 2014
    5
    Thanks. I will give it a try. Appreciate the link.
  11. aminkorea
    May 23, 2014
    5
    I just install ccminer from the link you provided and when I start the program I get an error that says the miner can't start because MSVCR100.dll is missing from my computer. Any suggestions?
    Edit: I googled the problem and installed the missing dll file but still get the same error. Can anyone offer some help?
    #11 aminkorea, May 23, 2014
  12. hu398
    hu398 New Member
    May 13, 2014
    12
    That's the Microsoft Visual C run time library v10, if you just downloaded the single dll file from somewhere then maybe try downloading the full runtime installer from microsoft and installing that. This dll file usually lives in the windows\system32 folder but would probably be picked up if you copied it to the ccminer x86 folder.
  13. xavier04
    xavier04 New Member
    May 24, 2014
    I have the exact same issue. Have you had any luck finding a solution?
  14. aminkorea
    May 23, 2014
    5
    I installed the MS Visual C and still get the same error.
  15. hu398
    hu398 New Member
    May 13, 2014
    12
  16. aminkorea
    May 23, 2014
    5
    I will give this a try, but my nVidia cards are not older, they are the new 750Ti Maxwell cards. Will post again once I have tried this version. Thanks for ur help.
  17. Syntor
    Syntor Member
    May 26, 2014
    60
    7
    I am running (2) GeForce GTX 760's..
    This is my string: ccminer30.exe -t 2 -a x11 -o stratum+tcp://mining.darkcointalk.org:3333 -u -p
    This is my clocking: Power Limit: 84%, Core Clock(MHz): +192, Memory Clock(MHz) +192, Fan Speed: 93%
    I am currently getting a VRel cap that is only letting me get @78% power% (not sure why I am getting that.. may need bigger power supply)
    My temps are 63c on my Evga, and 77c on my Galaxy (doesn't have nearly the cooling fin size as the Evga)
    I am currently getting @2040khash/s from the Evga and @2010khash/s on the Galaxy!!
    I am pretty happy with the output!!
  18. Burb
    Burb New Member
    May 26, 2014
    Hello,
    I've been mining with ccminer on my GTX 780 over the past 3 or 4 days. However, it has stopped working.
    It's been working fine over the weekend, getting around 2000 khash/s. But now, all I get is this error:
    For reference, here is my .bat:
    I've tried with two different pools, and I get the same error on both. Neither the GPU or the CPU is overclocked.
    Using minerd-corei7-avx instead of ccminer works, so there is nothing wrong with the pools. However I only get around 500 khash/s with cpu mining.. I'd rather use ccminer.
    I'm also getting artifacts on the windows desktop sometimes when I try to start up ccminer, little green or white dots appear at times then disappears. And sometimes when I try to start up ccminer the screen blacks out and I get a "nvidia driver crashed and has been restored error".
    I've been using MSI Afterburner while mining this whole time and set the fan speed to 100%, so temperatures have been low.
    All was working fine yesterday... Did my graphics card break or something?
  19. Syntor
    Syntor Member
    May 26, 2014
    60
    7
    Following.. I get the same error maybe 3-4 times an hour, and just chalk it up to the fact that the program is just a tweak off of a cpu mining program..I just get that as a random error.. but the next line it goes right back to accepting..
  20. scavenger7
    scavenger7 New Member
    May 25, 2014
    17
    7
    KBomba's build with 2.1 is nice for the older nVidia cards like my GTS 450. I'm averaging about 100ish khash/s which is nicer than the 40-50ish from my CPU. Together it's nicer. definitely nice to see it working now.
  21. dchoquette
    dchoquette New Member
    May 29, 2014
    Im having some trouble with ccminer. The program loads and is supposedly hashing but no shares are accepted/found and the pool doesn't detect the work even if it was working. Here is what is in my BAT file: "ccminer35.exe --algo=x11 -o stratum+tcp://mining.darkcointalk.org:3333 -u dchoquette.1 -p stuff"
    I would really appreciate some help!
    I gotta say this is really confusing. and I was excited to use my gpu again (evga gtx760)
  22. aadje93
    aadje93 New Member
    May 23, 2014
    37
    Do you see hw errors dchoquette?
    I have overclocked my 780 a little and it has zero error with ccminer 1.0beta (not yet tryed the new version, saw some comments that it doesnt work that good)
  23. Uleepera
    Uleepera New Member
    May 30, 2014
    7
    Has anyone tried this? I started out with darkcoin the other night running two systems whit the cpuminer just to see how everything worked. Had zero issues so I'm moving over to one of my GPU setups. It seems gpu support for darkcoin is sketchy at best. I've tried sgminer (4.10) both regular and x11 versions with no luck as they just keep crashing.
    I found in a different forum a suggestion to use ccminer (1.0) which is supposed to specifically support nvidia gpus. I'm using drkpool.com and in the cpuminer I get a message indicating when I've completed a hash (yay!!!) but with CC I don't see any indication when I've completed a hash nor does the drkpool website seem to register any progress either on a kh/sec or valid hash count. the start-up for seems easy "ccminer35.exe --algo=x11 -o stratum+tcp://drkpool.com:3333" plus -u/-p tags.
    drkpool doesn't even seem to realize that ccminer is logged in although it doesn't seem to have any issues with logging on.
    Any thoughts? I'd really like to get beyond 200ish kh/sec numbers.
    Thank you for reading.
  24. aadje93
    aadje93 New Member
    May 23, 2014
    37
  25. rumple
    rumple New Member
    Apr 3, 2014
    13
    Thanks for the suggestion, but I get the same failure during the build. The make output shows it is using options compute_30 and compute_35, but no sign of anything like compute_21. Do I need to add some option to the "configure" command?
  26. Uleepera
    Uleepera New Member
    May 30, 2014
    7
    I appreciate the suggestion. Why is that pool better than the one I'm using?
    I double checked and that is the same version of ccminer I've been trying to use.
    #26 Uleepera, May 30, 2014
  27. Syntor
    Syntor Member
    May 26, 2014
    60
    7
    Double check your ccminer version inside of 1.0, there are ccminer30, ccminer35, and ccminer50 depending on your card computing.. I use 2 GTX 760's and have to use ccminer30, I was getting the same thing you were getting before I switched.. I think the default is ccminer35, check your string.. Here's mine for my 2 cards:
  28. Uleepera
    Uleepera New Member
    May 30, 2014
    7
    What is the difference between them? The documentation doesn't seem to have been updated for this.
  29. Syntor
    Syntor Member
    May 26, 2014
    60
    7
    You want to change yours to ccminer30, I am running 2 GTX 760's and with a little tweaking I am getting @ 2.05mhash/s out of each.. Here is my string:
    MSI Afterburner settings: Power Limit : 84% ( I keep getting VRel cap limit @ 75%, think I need a bigger power supply), Core Clock: +192, Memory Clock: +192, Fan Speed: +84, My temps are at 73c and 67c ( I am running one EVGA and one Galaxy), the Galaxy has half the cooling vents as the EVGA hence the higher temp..
  30. Syntor
    Syntor Member
    May 26, 2014
    60
    7
    Not 100% sure of the explanation, but it has to do with the computing power of the card itself.. sort of like when dealing with cudaminer.. some cards use K6x24 etc.. and some use T6x24 etc.. It has to do with how the card is rated or something like that.. just change the beginning of your string and try it, if you get the same error, change it to the other one.. I promise once you get the right one.. you will know!!
